List of members with 2JZ-GTE swap...
true dat sc51
here's the latest photo of my gte beast...undergoing surgery again around the november time frame. i'm gonna be adding gsc s1 269 duration cams, titan cam gears, titan billet timing tensioner bracket, rmr -8 fuel rail with 1000cc injector dynamcics fuel injectors, and a alky control meth kit that's gonna be running 100% methanol. i'm gonna be shooting for 600+ rwhp on 91 octane with methanol injection
true dat sc51
Built JDM Supra 2JZ-GTE w/6 speed C's short shift Getrag, JDM Supra LSD and half shafts in my car. RPS triple carbon-carbon clutch. Carillo H beam rods, CP pistons, o ringed block, full Ferrea head port/polish with +1 valves, Titan 272 high lift cams, Titan cam gears, shimless buckets, Hypertune intake w/102mm throttle body, Full Race exhaust manifold, ID2000 injectors, Magnafuel 4103 fuel pump w/-10 feed and -8 return to flex fuel sensor. ProEFI ECU w/fuel and oil pressure sensors, 5 position I boost controller, flex fuel operational. Garrett GTX4202R turbo w/4" downpipe and mid-pipe, Y'ing into dual 3" magnaflows. Greddy 4 row I/C with 4" cold side piping. Power - anywhere from 711 rwhp at 19.5 psi to 1050 rwhp at 40 psi on E85 depending on boost setting.
