Update SC400 weight, gte single, Bride, and R154 (pics)
Well, went to the dump today and it came in at 3640. Still pretty heavy for my tastes, but Im workin on it. Here's a relevent list up to date...
I threw some pics in for fun...
- gte swapped and singled
- 4 row Greddy FMIC
- R154 swap
- some HEAVY moda 18"ers, (those will be next to on the lightenthefatassload list.)
- Optima Red Top
- Rear tire out, along with some of the junk back there, carpet is still in though.
- Got one BRIDE Low Max in the other day (custom brackets)
wow, the shifter mod you did put the **** that high? i'm definitely just heating and bending mine. from my drawings and measurements, the modification will put me 1.5 inches lower than stock.
btw, don't worry about the weigh, just turn up the boost a little. =)
*Edit: Your car is a heavy *****
SC4 has bigger brakes than an SC3, and the Optima batteries are good but heavy.Prob. the wheels getting you as much as anything. A 1/4 mile slip from a local drag strip is what I would like to see.
I also did a little research and here is what I found out:
Curb Weight
3506 lb (1590 kg) (1992 SC 300 manual)
3505 lb (1590 kg) (1992 SC 300 automatic)
3604 lb (1635 kg) (1992 SC 400)
So, my car is heavier than what it started as.. YIKES! I always said she had a fatasss but geez.
