SC400 Cooling fan fluid requirements ...
Old 03-11-08, 06:37 AM
lexdud
lexdud's Avatar
Default SC400 Cooling fan fluid requirements ...
I was checking the fluids on my SC400 and noticed the fluid level for the cooling fan was a little low. The requirement is for Dextron II ATF, which was the standard for 1993. Moving forward to the present time, Dextron III is the current standard.
I was just wondering what Dextron III ATF you would recommend? I went to the parts store and quickly became overwelmed by all the choices I had.
Thanks ...
Old 03-11-08, 09:17 AM
shern
shern's Avatar
Get the Mobil 1 Synthetic Dexron Fluid. It is backwards compatible with Dexron II and good stuff!
Old 03-11-08, 11:55 AM
Spitfire86
Spitfire86's Avatar
How often should this fluid be changed and should we do a full flush or just get a turkey baster and suck the reservoir out and refill?
Can the new synthetic fluid mix with the hold fluid?
Old 03-11-08, 12:29 PM
lexdud
lexdud's Avatar
Thank you shern, I'll do that. The fluid in the reservoir is a light purple and VERY clean. The only reason I am at all concerned is that it is a little low.
Thanks again ...
javohio
07-10-15 09:15 PM
sjc2467
04-06-13 03:58 PM
Din
SC- 1st Gen (1992-2000)
09-27-02 05:53 PM
Quick Reply: SC400 Cooling fan fluid requirements ...
