How much HP will the stock 95 SC400 trans handle?
Old 01-16-08, 06:46 PM
cdk4219
cdk4219's Avatar
Default How much HP will the stock 95 SC400 trans handle?
I was thinking about installing some nitrous on the SC400, and was wondering if anyone knew the limits of the stock trans? I assume that this is one of the weak links of the drivetrain, the next being the head gaskets (maybe?) If the trans can take the abuse, then a 150 shot would be in order.
Old 01-16-08, 07:07 PM
LexusFTW
LexusFTW's Avatar
the sc400 trans is basically the supra TT trans with different gearing. it can take ~450 whp with a trans cooler.
Old 01-16-08, 08:34 PM
ihiryu
ihiryu's Avatar
Really? That's good to know, so I'm assuming the auto supra shim mod thing applies to us too
Old 01-17-08, 08:26 PM
vwynn
vwynn's Avatar
shimming as in making the car shift harder? if so then yea
Old 01-17-08, 08:32 PM
StiCk3
StiCk3's Avatar
it would hold up fine to the Nitrous, but if you want to make more power, you might want to look into a rebuild kit. How many miles are on your tranny?
Old 01-18-08, 07:50 PM
cdk4219
cdk4219's Avatar
80 thousand miles. It shifts fine and I pulled the pan and there isnt really any clutch or other wear material on the bottom. Trans cooler and spare trans it is. 450 is pretty good.
LPA
SC- 1st Gen (1992-2000)
04-02-11 09:08 PM
deckerson5
01-30-09 09:39 PM
tritron
07-01-08 08:54 PM
surferlife
02-11-08 10:19 AM
Quick Reply: How much HP will the stock 95 SC400 trans handle?
