Squealing noise from new clutch
Old 07-10-07, 01:40 AM
dinhnerz
dinhnerz's Avatar
Default Squealing noise from new clutch
I've just recently changed the clutch to a stage 3, 6 puck clutch.
I have a squealing noise coming from what it seem the clutch.
How can I tell its from the clutch? Every time I press down on the clutch
it goes away.
What I want to know if this is normal?
Old 07-10-07, 10:19 AM
Gunnar
Gunnar's Avatar
Sounds like clutch chatter to me. It'll likely get quieter or even go away as you break the clutch in more.
Old 07-10-07, 01:24 PM
na4now
na4now's Avatar
Does it do it driving down the road? If it only does it, on release, thats a characteristic of a 6 puck sometimes. Should have went with a regular disk.
Old 07-10-07, 01:43 PM
dinhnerz
dinhnerz's Avatar
It only stop when clutch paddle is pushed in. Otherwise driving and at idle it makes that noise.
Old 07-10-07, 01:49 PM
na4now
na4now's Avatar
Somethings wrong then. Did you replace the throw out bearing? Maybe its not installed correctly? Either way, sounds like its time to drop the tranny again.
Old 07-10-07, 09:27 PM
AdvanSC300
AdvanSC300's Avatar
It's the throw out bearing,I have seen this problem before.
Old 07-10-07, 10:37 PM
DasBach
DasBach's Avatar
Mine makes that noise too. I deploy in less than a month so the car will be sitting for 7 months, and will be NA-T'd when I get back so should I just wait for a new clutch setup or will it hurt anything if I drive around about a month with it squeeking?
Old 07-11-07, 12:53 AM
dinhnerz
dinhnerz's Avatar
Yeah, I've replaced the throw out bearing and the pilot bearing as well.
Before I spend the whole day dropping the tranny and putting it back.
To inspect it.
Could it be anything else? Beside the throw out bearing.
Greased everything up really good too
Chattanoah
06-30-16 09:24 PM
klurie
08-16-11 09:23 AM
snook
SC- 1st Gen (1992-2000)
28
11-26-09 09:03 PM
93sc3005sp
07-24-08 08:42 PM
hwallen172
01-08-03 01:10 AM
Quick Reply: Squealing noise from new clutch
