2JZGTE guys, does your A/C work? Parts I. and II.
Old 05-28-07, 01:29 PM
USAF_RT
USAF_RT's Avatar
Default 2JZGTE guys, does your A/C work? Parts I. and II.
I am trying to figure out where to start on this whole problem. The clutch is not engaging on the compressor, but the lines hold pressure very well. So I am assuming it's in the wiring somewhere. Can anyone lend advice as to where to start looking?
I am gonna dig into the FSM's, but if someone else has a quick fix that would be great.
Old 05-28-07, 01:39 PM
csaxon
csaxon's Avatar
The compressor will not turn on if the refrigerant is low because the "low pressure safety switch" prevents the compressor clutch from engaging if system pressure is low. This protects the compressor from possible damage caused by a lack of lubrication.
One of the first things you should check is compressor engagement. If the compressors magnetic clutch is not engaging when the A/C is turned on, the problem may be a blown fuse or a wiring problem.
If the fuse is blown, replacing it may restore cooling temporarily. But the underlying reason for the fuse blowing in the first place needs to be identified and corrected to prevent the same thing from happening again.
If the magnetic clutch is receiving voltage but is not engaging the compressor, the clutch is defective and needs to be replaced. If there is any evidence of leakage around the compressor shaft seal, the seal should also be replaced.
If the clutch works but fails to turn the compressor (the belt may squeal in protest!), the compressor has seized and needs to be replaced.
Old 05-28-07, 02:23 PM
USAF_RT
USAF_RT's Avatar
Yeah I appreciate that. But I need someone with 2JZGTE wiring knowledge. There is an input to the ECU from the A/C controls (A34), and a wire out to the Magnetic Clutch Relay (A23). I am curious if those are the only two wires that need to be addressed during the swap. I did not do the swap, so I am not sure if something was overlooked. Other than that, the car runs great.
Old 05-29-07, 02:30 PM
kyoso23
kyoso23's Avatar
Toggle switch it.
Old 05-29-07, 07:39 PM
got_trd
got_trd's Avatar
check that ground wire on the a/c compressor... they've known to break from the engine torquing over when revved and such.
Old 06-23-07, 02:08 PM
USAF_RT
USAF_RT's Avatar
Default 2JZGTE - A/C Wiring Question...Part 2
Can anyone tell me what actually needs to be rewired in regards to the A/C Magnetic Clutch and A/C Climate Control?
Do all of these have to be rewired from the individual 2JZGTE sensors to the SC300 climate control???
A/C Ambient Temp Sensor
A/C Lock Sensor
Engine Coolant Temp Sensor (A/C System)
A/C Solar Sensor
A/C Evap Temp Sensor
Old 06-25-07, 10:17 AM
sc250tt
sc250tt's Avatar
it should plug up and work .at least mines did.
Old 06-25-07, 09:37 PM
VGnomore
VGnomore's Avatar
He is talking about a 2jz-gte swap.....If you find the answer I would love to know as well
Old 06-26-07, 04:45 PM
USAF_RT
USAF_RT's Avatar
I will dig into it a bit more in about a week, I am sure I will figure it out.
Old 06-26-07, 04:51 PM
neurocity
Neu`roc´i`ty
neurocity's Avatar
El-Mergo-Threado
Old 06-26-07, 04:55 PM
2JZ_SC
2JZ_SC's Avatar
I can get a EWD for a US 2JZ-GTE MKIV supra.
Old 06-27-07, 01:56 AM
Ali y0
Ali y0's Avatar
updates y000!
Old 06-27-07, 02:28 PM
USAF_RT
USAF_RT's Avatar
If EWD = Wiring Diagram...I have that for the 94 Supra, 97 Supra, and 97 SC300. It's just a matter of chasing down all the wires and figuring out which sensors should be checked first, checking for the easiest fixes before digging further.
silentdub
04-29-21 08:57 PM
Therrol
RX - 1st Gen (1999-2003)
05-26-19 12:47 PM
smesseng
Maintenance
06-09-14 01:55 PM
SleeperTTz
06-03-12 07:48 PM
jmoc1
05-18-12 11:45 AM
Quick Reply: 2JZGTE guys, does your A/C work? Parts I. and II.
