standalones (1uz-fe)
Old 12-06-06, 11:44 AM
tuninghaus
tuninghaus's Avatar
Default standalones (1uz-fe)
what are the options for standalones for the 1uz- 2uz-fe's?
are the LS400 and SC400 wiring harness/ECU the same?
Old 12-06-06, 12:19 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
welcome, let me show you to our engine section.
Old 12-06-06, 02:26 PM
MJHSC400
MJHSC400's Avatar
From all the research I've done, there aren't many standalones designed to control an engine with an automatic transmission....
Motech makes them, though I haven't heavily researched the products they offer, but be ready to spend $3000 and up on a standalone that can control the 1UZ with an auto---
OR-- Do a manual swap and somehow pull it off for $1500 if possible, and get a Perfect Power PRS8 standalone for $1200--
That's one of the least expensive standalone's available, and the company is reputable....
This combo with a light flywheel would make a modded 1uz SC400 m/t a true sports car and would be a lot of fun to drive..
Not to mention power loss is less through a manual tranny-- about 5% or so less.... or about 15 hp when you're at 300 at the crank...
That would be 250 at the wheels for the standard mod list plus a manual tranny... {tex headers, reground exhaust cam, BFI, piggyback tune, full custom exhaust} Plus, you could throw in a supra TT a/t lsd, raise the rev limiter to 8000 rpms, and do a crazy aggressive tune with a manual tranny-- The peak power with those mods goes up even more and finally falls off around 7500 rpms--
That would be a fast car-- probably able to run mid/hi 13's
Old 12-06-06, 05:19 PM
StiCk3
StiCk3's Avatar
motecs M800, autronic SM4, many others out there...
check the fuel, tuning section here. VERY informative with all 1UZFE topics
www.lextreme.com
Old 12-06-06, 05:26 PM
MJHSC400
MJHSC400's Avatar
www.1uzfe.com also has a lot of good performance links from his page to a lot of guys that have done swaps into dirt track cars and other various cars, such as a Ferrari F40 replica-- with a TT 4.0 , a porsche 944 with a 4.0 swap, etc..
This guy has tons, absolutely tons of good links on swapping the 1UZ which will inherently be a good info. source for standalone management and tuning...
Old 12-07-06, 12:29 PM
tuninghaus
tuninghaus's Avatar
thanks a lot guys.. excuse me for not posting it in the right section
i plan on using the supra getrag 6spd.. those are bullet proof and probably good for 1200+whp (with the right clutch).
would a LS400 1uz-fe wiring harness and SC400 wiring harness the same or are they different?
Old 12-07-06, 03:17 PM
MJHSC400
MJHSC400's Avatar
The engine harness is most likely Identical or near identical as far as function, but lengths of wiring may differ--
As the engine and trans is identical except for exhuast manifolds, it would lead me to believe as such.
Timd234
17
06-27-14 10:03 PM
Dutch
01-07-08 03:59 PM
jwar
01-09-04 06:08 PM
suprang
12-31-03 12:30 AM
Quick Reply: standalones (1uz-fe)
