Check Oil Light
Check Oil Light
Ever since I got back from my two-week vacation, the oil light comes on and off while I'm driving (although I haven't noticed anything wierd about the way it drives). I have checked the oil in the mornings and the reads at the "F" line, so I'm not sure what's causing this. Maybe an oil change that's coming up will resolve this?
some times it does that when it was over filled or also check your senser might be broke or let half a qt out and drive it around and see what happns still acting up then put it back in... just might be that sensor
I would definitely suggest checking the oil level sending unit, which I believe is on the side of the engine block on the driver's side. First, make sure that there is not an intermittent wiring problem to your panel (sounds unlikely in this case) by just grounding the connector at the sending unit, and looking for the light on the panel.
Sometimes it is just a loose connection, but if that doesn't solve the problem, then almost certainly you just need a new sender unit... easy (but messy) to replace.
http://www.***************/lexusoxygensensor.htm
