question on 5 speed trannys.
There is a bit more to it than might at first appear.... To confirm other postings: You will need a different clutch and T/O bearing as indicated, the stock Lexus 5-speed uses a totally different design. Then, as mentioned, the rear axle ratio on the lexus will NOT be compatible with the Getrag, so you will need to replace the rear end with a Supra unit. In addition, the drive shaft length will need to be shortened to fit. Unfortunately, I do not believe a supra driveshaft will do the trick.
Finally, I understand that a bit of metal work (read: BIG sledge hammer) is necessary on the tranny tunnel to make adequate clearance for the Getrag.
Hope this helps
Hope this helps
supra247
SC400 / 300 Classifieds
02-22-09 06:50 PM
