Throttle Body Spacer for SC4?
Old 01-19-06, 09:34 AM
MikeSC400
MikeSC400's Avatar
Default Throttle Body Spacer for SC4?
I have a 93' SC4, can i find a throttle body spacer for my car, or does no one make one? Is it worth it? Tried searching the forums but no results came up.
Old 01-19-06, 11:09 AM
933005spd
933005spd's Avatar
Hey buddy,
Don't mess with the spacer. I have a throttle body guy work on my stuff. For the 1UZ he said this:
The Lexus TB is pretty well built already. It does not have the problems of
the Dodge TB's. The easiest and most effective things I can do for it is to
modify the shafts and knife edge the blades. It is a pretty good sized TB
already and enlarging the bores probably will not see much gain. I will
break through a few vacuum ports to enlarge it also which is a problem
I am having him do this to my TB and can post back when I evaluate it.
Peter
Old 11-08-17, 01:33 PM
Yordan1k
Yordan1k's Avatar
I'm looking for a 98 gs400 throttle body spacer, I know it's the 1uzfe engine , but all I find is for an sc400 are they the same specs ?
Old 11-10-17, 08:57 PM
1997Soarer
1997Soarer's Avatar
If the spacer is for a 98-00 SC400, yes. If it's for a 92-97 SC400, no. The pre-VVTI 1UZ-FE motor uses a different intake manifold and throttlebody than the VVTI 1UZ-FE.
sagarx
12-03-20 03:50 PM
x2mkx
05-18-09 08:07 PM
Splatsc300
SC400 / 300 Classifieds
06-14-05 12:14 AM
Quick Reply: Throttle Body Spacer for SC4?
