Compression test on a '98 SC300 revealed weird results!
Old 10-12-05, 10:17 PM
Paulus
Paulus's Avatar
Unhappy Compression test on a '98 SC300 revealed weird results!
Thinking about buying a beautiful '98 SC300. Black on black w/65,000 miles. Original owner, and well cared for...I thought. Prior to pulling the trigger and buying the car, I had a local garage do an engine compression test. Compression readings were: 1=180, 2=180, 3=150, 4=150, 5=120, 6=130. Car looks and drives fantastic. I could not detect any oil burn or other signs of engine wear. Not sure what to make of last 2 readings and the huge difference between cylinders? Could it be a blown head casket? or bad rings or valves? Still want to get car, but I'm a bit concerned about the engine. Any ideas?
Old 10-12-05, 11:27 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Definately isn't right somewhere. If there are no physical signs of problems, it's either seeping between the cylinders or you need to try it again just to make sure the guy that did it didn't get lazy when fitting the last two.
In a worst case scenerio, imagine the possibility the head gasket may have blown either between the cylinders or at the water jacket and they stuck some head sealant back in there to keep it together.
Old 10-12-05, 11:33 PM
kietlander
kietlander's Avatar
i will be looking at a SC this sunday. what should the compression be?
Old 10-13-05, 12:13 AM
codetoad
codetoad's Avatar
Could be the compression gauge itself. Sometimes they don't read right. Get a different one and try it out.
Old 10-13-05, 12:21 AM
SUPRMSC
SUPRMSC's Avatar
Someone probably wrong with the head bolts or headgasket
CoOl21
07-14-16 09:53 PM
David_K
27
11-17-15 12:18 PM
Luv Da Lex
01-21-06 05:54 PM
adidosc
SC- 1st Gen (1992-2000)
09-16-05 12:17 PM
lilmac
12
04-05-05 10:55 PM
Quick Reply: Compression test on a '98 SC300 revealed weird results!
