2013 IS 350 side mirrors adjust inwards not downwards
Help!! in selecting reverse my outside mirrors tilt inwards not downwards - what adjustment needs to be made?
While you are making sure that you are keeping your foot on the brake, put the car in reverse. While it is in reverse (and you are keeping your foot on the brake), use the mirror adjustment buttons to adjust each mirror to the position that you want it to go to when you are backing up. After you do that, those positions will be memorized, and the mirrors will move to those positions when you are in reverse.
Note that, if you change the normal mirror positions, you will need to re-set the reverse mirror positions.
(Also note that you posted in the NX forum, and it appears that you have an IS.)
Jeeze... this question has been answered many times! Search first will ya?? Or RTFM...
Anyway, put your car into reverse, adjust your mirrors to where you want them to be pointed during reverse, then shift back out of reverse. Your mirrors will move back to your normal position. Make sure your mirror adjustment selector is pointing left or right, then shift to reverse again to test. Your mirrors should move to where you adjusted them earlier.
AL13NV8D3R
02-08-18 11:01 AM
5PM
11-16-15 04:21 PM
