NX - 1st Gen (2015-2021)
Underhood LED work light
Old Mar 10, 2017 | 09:38 PM
lavangbay's Avatar
lavangbay
Default Underhood LED work light
Hi,
I just installed some LED lights under hood for cases when I need to work under the hood (like check oil levels, replace engine filters, checking fuses, battery, etc...) I thought it's pretty helpful. I'm including links to items I used to make it.
  1. LED Light bar (http://www.ebay.com/itm/122307690750...%3AMEBIDX%3AIT)
  2. LED switch (http://www.ebay.com/itm/222302914404...%3AMEBIDX%3AIT)
  3. socket connection (http://www.ebay.com/itm/401257692376...%3AMEBIDX%3AIT)
  4. Battery Terminal fuse holder (
    Amazon Amazon
  5. LED wire 22awg (http://www.ebay.com/itm/2-pin-30-FEE...EAAOSw8w1X7rhT)
Total time is about an hour or so.
Attached Thumbnails Underhood LED work light-20170310_202437.jpg   Underhood LED work light-20170310_202508.jpg   Underhood LED work light-20170310_202340.jpg   Underhood LED work light-20170310_202350.jpg   Underhood LED work light-20170310_202329.jpg
Old Mar 13, 2017 | 12:45 PM
2slow's Avatar
2slow
Very nice! I planned to do this as well, but instead of a regular on/off switch I'll be tapping into the hood open/closed switch so it will turn on automatically.
Old Mar 13, 2017 | 12:50 PM
typocl's Avatar
typocl
I use one of these in the utility area of my house
https://www.amazon.com/T-02-Anywhere-Portable-Wireless-Magnetic/dp/B00J4EQVPG/ref=sr_1_2?ie=UTF8&qid=1489434561&sr=8-2&keywords=motion+sensor+light+led+battery+powered https://www.amazon.com/T-02-Anywhere-Portable-Wireless-Magnetic/dp/B00J4EQVPG/ref=sr_1_2?ie=UTF8&qid=1489434561&sr=8-2&keywords=motion+sensor+light+led+battery+powered
I wonder if I can just hot glue that under the hood
Old Mar 15, 2017 | 12:49 AM
lavangbay's Avatar
lavangbay
https://www.amazon.com/T-02-Anywhere...attery+powered
I used double sided tape to the hood and it've been over a week with hot weather in California (around 85 degrees at highest now) and it seems to be ok for now. Not sure how it will hold up once temperature reach 100, we'll see..
Old Mar 15, 2017 | 10:36 AM
no1SomeGuy's Avatar
no1SomeGuy
I use one of these:
Amazon Amazon
Works on any vehicle and takes seconds to setup. They have a newer LED version too.
Old Mar 15, 2017 | 11:02 AM
NXOwner's Avatar
NXOwner
From: Driving a UX Hybrid F-Sport! (in So California)
So, what happens if your car breaks down on a secluded highway at night because of a dead battery (but you don't exactly know it's a dead battery)?
Or...what if you have to disconnect your battery because you are working on something under the hood that requires you to disconnect it?
Either way, you may have no lighting using the above solutions to troubleshoot.
This is where a good old-fashion flashlight (torch) comes in handy. Any portable, battery-powered lighting system would be best. I keep a flashlight in my car. I also have a portable tire inflator which has a built-in flashlight. Finally, I carry an inexpensive light shown below that has a hook that allows me to hang it anywhere...
Old Mar 21, 2017 | 12:27 PM
starbai's Avatar
starbai
not afraid of engine heat destroying it?
svagusta
Lighting
Oct 26, 2010 07:26 PM
RA40
Lighting
Sep 15, 2005 07:52 PM
