NX - 1st Gen (2015-2021)
disable stop start system for NX
Old 09-28-16, 05:14 AM
fisherga
fisherga's Avatar
Default disable stop start system for NX
Is it possible to permanently disable the stop start system? I do not want to push the disable button every time I start the engine.
Old 09-28-16, 09:45 AM
GS3Tek
GS3Tek's Avatar
Hi. Welcome aboard.
For the smart-key system it doesn't have a physical key to start the car. Even if you could disable it, there's no other way to start it.
Am I understanding your question correctly?
Old 09-28-16, 12:18 PM
JDR76
JDR76's Avatar
Received 1,603 Likes on 1,021 Posts
^^^ I assume the OP is referring to the engine start/stop feature that turns off the engine at a stop light, for example, to save fuel. While Lexus provides this feature only on the hybrid in North America, they've been providing it on non-hybrid models in other markets. Since the OP is in NSW, I assume his/hers has it. Lexus seems to equip the NX in New South Wales very well.
To the OP, I do not believe there is a way to permanently disable it. It has to be turned off each time you start the car.
Old 09-28-16, 02:56 PM
fisherga
fisherga's Avatar
Default Disable the stop start system on NX
My new NX200T is equipped with the feature that turns off the engine when stopped at the lights. There is a disable button. The default means that I have to press the button after each engine start. I have found that I often get a message to push the brake down firmly to activate the stop start feature. In many instances it is not necessary to push the brake pedal down as firmly as required. The stop start feature does not activate and the engine continues to idle. The amount of fuel saved by the stop start feature would seem to be negligible. While engine stopped (in the stop start mode) with the air conditioning running, the engine restarts after a short time and idles to provide power for the aircon thus negating the stop start feature anyway.
Thanks for the comments.
Old 09-29-16, 07:20 PM
olgzr
olgzr's Avatar
The 2015 and up F150's also have this feature on some of their engines. People on that forum have been looking for a way to disable this feature without success yet.
Old 10-01-16, 05:05 PM
MKenM
MKenM's Avatar
My Jaguar has stop/start and there was a simple fix just by unplugging a wire. No codes were thrown and it worked perfectly. Stop/Start in city traffic is a PITA.
Old 10-20-16, 11:07 AM
mindanalyz
mindanalyz's Avatar
Interesting that it does not have a way to remember the settings. My X3 remembers the settings but when I select Eco mode the start/stop goes back to on; I do not care much for this feature so I always leave it off [and drive in sport mode most of the time]
Note: I remember I read somewhere that when BMW equipped the X3 with this feature, it could not remember the settings, but after some complains they decided to add it
Old 10-20-16, 04:38 PM
MKenM
MKenM's Avatar
Since I never use eco I did not know that there is a stop/start feature. I always thought it was a PITA with the Jaguar.
Old 10-20-16, 04:45 PM
Htony
Htony's Avatar
When I had Bimmer 2015 X5 there is a button to push to disable it. Until I push the button again it stays disabled.
ALE81
21
09-18-15 04:29 AM
kl323
04-04-11 12:05 PM
jayz250
03-04-09 04:45 PM
MythBuster
06-18-08 12:00 PM
aznpapaya
09-20-07 09:46 AM
Quick Reply: disable stop start system for NX
