FL FS:RX330 dash kit & accessories
*EVERYTHING HAS BEEN SOLD!*
I've recently traded in the wife's RX330 and I removed all of the audio equipment and remote start that I had installed, so most of it is now up for sale. I've linked to my install thread below but it was a Kenwood DNX5120 with steering wheel controls and the factory amp (non-ML radio) kept in use. I'm willing to sell the parts individually, although I'd like to do a package deal and get rid of it all at once. I'll list individual part prices (not including shipping), but I'd let it all go together for $120 shipped in the 48 states. Just FYI, the radio is not for sale as I'm using it in another car now.
https://www.clublexus.com/forums/rx-...nt-option.html
RX330/350 JDM Dash kit - $60
- I cut up and hot glued the plastic brackets that came with this kit to the sides of the radio so that it took up the small amount of extra space that this kit leaves, and you'll probably need to do the same depending on your radio. You can see the finished install in the thread linked above.
TYTO-01 wiring harness - $40
- This harness worked perfectly with my non-ML sound system and utilized the factory amp and sounded great!
PAC SWI-JACK steering wheel interface - $25
- Interfaces the factory steering wheel controls and can be programmed for various functions depending on what you want control of.
IM05 security bypass for remote start - $20
- Used to bypass the security system for a remote start installation.
Metra 70-8113 (brand new) wiring harness - $5
- I don't remember how I wound up with this harness (it may have come with the dash kit) but I didn't use it for my installation. Depending on your install, it may come in handy.
Interested in the IM05, too late for the other stuff, just installed an aftermarket HU in wife car after 6 years of owning it (great price for it all though)
Did you install the remote start or someone else, wondering the difficulty of it.
Thank you...........
steve
steve
i did the remote start, and it wasn't really any harder than any other that I've done, aside from the door lock issue that I ran into when trying to use the factory key fob to activate a simple remote start add-on, rather than using a dedicated remote. it just added a little time and required me to go back and rewire the locks, as well as order the new parts. Had i gone with a standard install in the first place, it wouldn't have been an issue...
Where in Illinois are you located? I'm flying into Midway tomorrow night, and will be up that way all week.
I've done a few older style remote systems, no bypass system needed, trying to get all the correct parts.
Northern suburbs, Libertyville, Lake Zurich.
PM if you'd like. I'll still be interested in purchasing it.
steve
Does fade work? I can't fade to work on my 2004 RX330 with this kit.
Note that the kit has changed in 2003. Instead of having RCA plugs to connect to the preamp of the radio, it now has wires you connect to the amplified speaker wire outputs.
ARRUDASGS
04-02-08 11:24 PM
