CD player won't play
Forum Administrator
Sick,
Take the CD cartridge out of your GS (that works) and try it in his. That will at least eliminate part of the CD system as an issue. Plus it removes the 'duh' factor for putting the CDs in upside down or bad CDs.
Make sure to use real store-bought CDs, not burned ones. Some burned CDs have issues in our players.
SICKLEX,
Remove the CD cart, and unplug the harness to the changer. It may need resetting, or it may have worked the audio output harness loose. If that doesn't work, check the same harness on the headunit side.
MW
MW
