1991 Lexus LS400: How to Remove Steering Column Cover
Old 12-24-11, 05:13 PM
bluebluegr
bluebluegr's Avatar
Default 1991 Lexus LS400: How to Remove Steering Column Cover
Hi,
The steering of my '91 LS400 is stuck in the "up" position and I'm looking to fix it (apparently its likely a blue wheel that is off course) as I've seen it done a few times on this forum and others. The thing is I can't seem to get the steering column cover off. I removed two screws underneath the column and one on the lower right of the front of the steering wheel. The two steering column pieces still seem pretty firmly stuck. I believe there is a clip on both sides, but I'm a little scared to just "pull" it in case they break. Does anyone have any advice or should I just "pull".
Thanks!
Old 12-25-11, 01:36 AM
bluebluegr
bluebluegr's Avatar
Default Figured it out
The secret was to telescope the wheel all the way out before pulling on the bottom console panel. Piece of cake!
cyfi66
02-23-19 11:30 PM
Vpanin
06-05-15 04:33 AM
shaft1
09-07-12 01:52 PM
snook
SC- 1st Gen (1992-2000)
10-10-09 05:48 AM
Quick Reply: 1991 Lexus LS400: How to Remove Steering Column Cover
