strange braking noise on 98 gs4
Old 05-14-05, 10:03 AM
rjheard
rjheard's Avatar
Originally Posted by sputniknyc
Please keep me posted on this. I hope this fixes my problem.
You're in NYC as well? Maybe we'll do a mini group buy and group install?
I would like to know if this fixes the problem too. I have the same problem and was about to replace the ball joints in an effor to fix it.
Old 05-14-05, 10:05 AM
sputniknyc
sputniknyc's Avatar
seems like whenever i put the car in in reverse and then brake...a click sound appears....same as when i put it from reverse to drive.....a click happens after i brake..
Old 05-14-05, 10:43 AM
ILOVEGIRLS
ILOVEGIRLS's Avatar
is the control arm only in the front? does the rear have some?
Old 05-16-05, 09:30 AM
sputniknyc
sputniknyc's Avatar
i beelive the control arms are only in the front.
On another note. Since I'm changing my suspensions, should I be changing anything else to resolve this strange noise? Bushings? lubing certain components?
Old 05-16-05, 10:21 AM
chowder
chowder's Avatar
before you go too crazy, are you familiar with the normal ABS pump hiss sound?
if you start the car quiet (no radio, A/C, etc), the first time you press the brake (e.g. in P shifting to R), the brake system in this car does some sort of calibration. it sounds like a hiss followed by a light clunk. the car doesn't even need to be moving to hear it. just start it quiet and hit the brake.
Old 05-16-05, 10:28 AM
sputniknyc
sputniknyc's Avatar
Hissing sound doesnt bother me at all and I do hear it. But I do hear clicks when I brake at times. It does sound like something is loose or it may be my brake pads.
Old 05-16-05, 11:32 AM
slickgt1
slickgt1's Avatar
Click, not a thump like noise? Click sounds like pads. A thump of sorts is bushings. Do you feel the noice through the car? I mean, do you feel the click vibrate through the car. If it is just an audible sound, it does sound like your brakes.
Old 05-16-05, 01:08 PM
sputniknyc
sputniknyc's Avatar
not loud thumping....more of clicking...i may just need to check my brake pads and its shims. WOuld aftermarket shim kits work or should I go with OEM shims?
slickgt: get any word on those control arms??
Old 05-16-05, 01:49 PM
slickgt1
slickgt1's Avatar
I don't know, but I am guessing that aftermarket shims will work.
nope no control arm bushings yet. They said they will contact me once they become available.
Old 05-21-05, 01:22 PM
STR8-UP-G
STR8-UP-G's Avatar
I also have the same problem. It happens almost every morning. I start the car, let it warm up a bit than i put it into reverse. Once the car starts moving and i tap the brakes, i hear that clunk. Very annoying. Please let me know if the dealer was able to help you.
Old 05-21-05, 02:05 PM
VVT-i
VVT-i's Avatar
Sound like the brake pads clicking noise. When I got my 2001 GS I'd experience the same noise after the car got over 15K miles and the brake pads about 30% worn out. Every morning when I back out my drive way and the first time I step on the brake pedal. I hear this thumbing/clicking. This is absolutely normal because the brake pads got worn out so the brake pistons will have to travel further to move the pads against the rotors.
Old 05-27-05, 09:12 AM
rjheard
rjheard's Avatar
That was my symptom too. Nearly every morning when backing up and turning when I applied the brakes I got a "clunk" or "popping" sound. I just had my lower ball joints replaced and I believe that's fixed the problem. I still notice an occasional sound but I think it's the brakes.
SNiiP3R
01-21-14 04:44 PM
PBalla
Maintenance
07-23-13 11:27 PM
GS350Lexus
06-14-11 04:05 AM
pompitup
08-17-07 02:32 PM
Mullet
Wheels, Tires & Brakes Forum
10-02-03 11:39 PM
Quick Reply: strange braking noise on 98 gs4
