saw smoke fumes out of hood.
Old 02-23-05, 07:49 AM
rm1
rm1's Avatar
Default saw smoke fumes out of hood.
I have a 92 ES300 and today morning when I parked the car firstly I smelled as if something was burning and then the moment I got out of the car I saw smoke fumes coming out of the boot of the car.
I got very concerned but by the time I reached inside the car for opening the boot they were already gone. And after I checked the boot I couldnt make out where exactly those fumes were coming from?
This did not sound normal to me? Has anyone had a similar experience before? Or is this engine trouble?
rm1
Old 02-23-05, 09:46 AM
khhoang
khhoang's Avatar
hi, when you say "boot" do you mean the hood? your car's symptoms may indicate you have leaking valve cover gaskets which is a very common maintenance issue on an aged/high mileage ES300. oil may be leaking on the exhaust which produce the slight fuming under the hood and the burning oil smell esp. thru the A/C vents.
Old 02-23-05, 10:40 AM
rm1
rm1's Avatar
Yes I meant the hood and you described my symptoms exactly. Burning smell through AC and fumes through hood.
What do I have to repair again and how much does it usually cost to get it repaired? An estimate will do.
Thanks for responding.
Old 02-23-05, 02:40 PM
khhoang
khhoang's Avatar
You have 2 valve cover gaskets a front and a rear. They're leaking if you have a buildup of black oily residue along the seals and probably along the engine walls.
Gaskets are about $30 for the pair (do use oem gaskets) and labor is where it hurts (4-5hrs). Lexus will charge you about $550p&l. My independent mechanic changed F&R valve cover gaskets, fuel filter, PCV valve, spark plugs(OEM platinums) all for $340 ($92parts+$236labor). You can also try calling a Toyota dealership for an estimate.
Old 02-24-05, 10:48 AM
rm1
rm1's Avatar
Thanks for being detailed. I will definately get quotes first and accordingly get it replaced.
nsghtbrwry
04-03-17 12:54 AM
CobraGSF
09-17-15 08:51 PM
zx5r
02-18-14 10:33 PM
I8ABMR
03-14-08 10:21 PM
Iron Sheik
06-16-03 04:38 PM
Quick Reply: saw smoke fumes out of hood.
