Oil Usage
Old 02-02-05, 04:17 AM
skyman
skyman's Avatar
Default Oil Usage
Twice now between oil changes at 5000 mile intervals my LX has used just about 1 qt. of oil. Lexus says this is within parameters and nothing is wrong. I have never owned a Lexus(two others) that has used oil. Anyone have a similar experience. My LX has 36000 miles.
Old 02-02-05, 11:03 AM
RTIS250
Yes. I drove the LFA.
RTIS250's Avatar
Yeah, 1qt every 5k is well within the parameters of oil consumption. I beleive 1qt every 1500 miles is on the border of acceptable. Or 1qt every 1000. Something like that. Keep an eye on the consumption, and make sure it doesnt get any worse, and make sure it is all ducumented through your local lexus dealer as to how much it consumes and when. I understand your frustration though...
Old 02-02-05, 01:14 PM
mburnickas
mburnickas's Avatar
It is a hard one to answer since some oils have a low Noack Volatility % and some are high. Some are low as 6.5% and some are over 16%.
Old 02-02-05, 10:56 PM
Lexusfreak
Lexusfreak's Avatar
Cool
You never mentioned if you are using regular "dino" oil or synthetic. I'm guessing dino......perhaps switching to synthetic will make a difference...... Let's put it this way, it won't hurt anything by changing over.
Old 02-05-05, 12:15 PM
toy4two
toy4two's Avatar
Default Lexus and Toyota both used oil
My MR2 NA and my RX300 AWD both used about 1 qt of oil b/w changes. My RX is very well maintained, all scheduled maintence at the dealer and I treat it right. I wouldn't worry about it.
I use Mobil 1 BTW and I just turned over to 60,000 miles. No smoke, no leaks.
Old 02-05-05, 01:04 PM
RA40
Super Moderator
RA40's Avatar
On mine it varies. Between some changes, the level hasn't changed so I won't need to add anything. Others, I'll have to put in maybe 6-8 oz. of oil. With intervals at 7,500-8K miles.
Old 02-05-05, 05:44 PM
JellyBean
JellyBean's Avatar
As long as the oil isn't leaking out, or being visibly burned (blue smoke out of tail pipe), then everything's fine at that loss rate (1 quart/5000 miles). Due to manufacturing tolerances, some engines use up more oils than others.
Old 02-06-05, 07:04 AM
mburnickas
mburnickas's Avatar
I agree somewhat. On the flip side if your processes vary that much, something is wrong. You SPC needs to be more dialed in.
All the cars I have owned I have never needed to add more the 1/2 qt due to break in on my diesel. My car does not use much for its 12K drains.
Old 02-12-05, 08:33 AM
Lexus_g3
Lexus_g3's Avatar
Default Lexus_gs
I’ve been experiencing the same loss rate on and off since I really started to check at around 40,000 miles on my GS 300. Last December I went to a Lexus dealer that I had not been to before for my regular change. Didn’t think to ask about what grade/type of oil they were using. After 5,000 miles I checked consumption and I was down over a qt. Took the car to my regular dealer and was told again that it was no big deal. On the other hand, I made a point of asking where in the manual does it say that on a long trip I need to carry a quart of oil…just in case.
No leaks and no visible blue smoke. This is my 8th Toyota product…have never had oil consumption.
Just a guess but agree that there may be some oil consumption on certain types of oil. Performance/fuel economy vs. oil loss.
This Tuesday, I’ve got an appointment with the factory rep and the senior service tec.
simonasj
07-28-23 01:51 PM
GXelmer
GX - 1st Gen (2004-2009)
11-14-18 01:34 PM
sokkie
12-03-17 10:22 PM
rx93
RX - 1st Gen (1999-2003)
25
12-24-06 10:45 AM
SGMIS3
09-24-06 09:40 PM
Quick Reply: Oil Usage
