Need help on ATF change!
I have look and read the post on the maintance forum, but could not find any step by step instructions on how to drain/fill the ATF. I alrdy have the Type 4 ATF. If someone could please tell me how or know where i can look to get the info. Also is it better to get it change at a service place or do it yourself?
Thank you for the response
I know you have an SC, but this link shows how to do it on the GS4. There might be minor differences in location and amounts of fluid, but it would help explain the basic process so you can get started. http://lexusmodz.netfirms.com/GS_DIY...il/index1.html
You just need to jack the car up in one of its safe spots enough so that you can access the transmission drain plug. Then loosen the plug and allow the 2-3 quarts of fluid to drain (there's quite a lot more fluid than 2-3 quarts in the transmission/torque converter combined, but 2-3 quarts is all that will drain). I would recommend getting a new transmission drain plug each time it's changed. Then pour 2 quarts of the T-4 back in through the fluid level tube under the hood, check it after the fluid has had ample time to settle, and add as necessary. It's really very simple, easier than changing the oil and filter, IMO.
If your car has upwards of 100,000 miles, a flush is advised against . Lexus recommends a drain and refill every 15k. But, a flush is the best way to clean out the tranny . . .at your own risk.
xxjad22xx
Performance & Maintenance
07-05-06 02:17 PM
