Speakers Blown out, need help!
I have a 2003 Lexus lx470 and all the speakers in the car are blown :/ I want to replace them and I just want to hear the best advice on getting it done, thanks
Are all your speakers blown or just the subwoofer? It's fairly common for the tiny Mark Levinson sub to get blown. Check out this thread:
https://www.clublexus.com/forums/lx4...subwoofer.html
I replaced mine a few years ago with a 6" JL 6w0-8ohm. I've heard that might have been discontinued a while back, so check ebay and see if you can find one. That's where I found mine.
I just replaced my two front door speakers with 6.5" speakers and it took a bit of cutting and fabrication. If you are not up to doing that type of work, I would recommend you take it to a stereo installer.
i repaired my moms subwoofer with a $20 kit, to replace the speaker surround, works fine. Should be able to do the same with the regular speakers
http://www.ebay.com/itm/86160-0W290-86160-OW29O-Lexus-LX-470-Mark-Levinson-Speaker-Repair-Kit-FSK-5S-/140886298600?pt=US_Speaker_Parts_Components&hash=item20cd7a4fe8
http://www.ebay.com/itm/86150-0W010-...-/130698667123
LX470 speaker repair
I also did a successful repair with the $20 kit. I documented the steps needed at https://www.clublexus.com/forums/lx4...p-by-step.html
It's not hard and does not require any special skills, just care and patience. Simply Speakers has surrounds for other speakers as well.
Why do you think all of the speakers are blown? That would be pretty unusual - might be the amp, not the speakers.
tftimm
SC- 1st Gen (1992-2000)
07-15-11 06:38 AM
