LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
2001 LX470 - High RPM at 75 mph
Old 09-04-10, 10:18 PM
jmanwaring
jmanwaring's Avatar
Default 2001 LX470 - High RPM at 75 mph
So I need some help diagnosing a really strange problem with my LX470. Sometimes (Not Always) when I accelerate onto the Freeway my LX470 will get up to 4500 RPM at 75 mph and will not downshift. I have noticed that if I put my truck into neutral and then back into drive it will return it is usual RPM level (2300 RPM).
Does anyone know what might be causing this?
Old 09-14-10, 11:51 AM
CACressida
CACressida's Avatar
How many miles on it?
Old 09-15-10, 06:03 AM
jmanwaring
jmanwaring's Avatar
I appreciate the response and apologize for not adding this initially. I have 110,000 miles on it.
Old 09-17-10, 02:19 PM
lex95se
lex95se's Avatar
the only think i can think of is something to do with the overdrive button.
do you always use it that button?
Old 09-20-10, 07:37 PM
osomoso
osomoso's Avatar
Make sure your overdrive is on. But may want to have it serviced.
Old 09-20-10, 09:49 PM
Jayson
Jayson's Avatar
When was the last time you had the tranny serviced?
Old 09-24-10, 05:29 AM
krye
krye's Avatar
sounds like you may have an issue with the overdrive. If you have not changed the transmission fluid, you may want to consider doing so.
Old 11-09-10, 01:16 PM
charlie@jd
charlie@jd's Avatar
sounds like you need a new tranny?
v8sedan
IS F (2008-2014)
09-21-15 04:26 AM
REG99GS3
Performance
14
11-14-06 05:11 PM
papachino
Maintenance
03-23-06 02:33 PM
papachino
03-17-06 05:25 PM
mdfdsc300
SC- 1st Gen (1992-2000)
05-02-01 02:16 PM
Quick Reply: 2001 LX470 - High RPM at 75 mph
