10-24-09, 06:44 AM
LX470 Rear Brake Sound
Hey guys,
Having this problem recently where I took the car to change the brake pads but now when you step on the brake moving from idle state you'll hear the sound of the rear brakes as if they're stuck and gettin lose when the car starts moving.
I took it back to the mechanic and he told me there rust around there, else everything is fine.
Still thinking that rust will not have anything to do with it.
LX470, 2003 Doing 80K
Any Help...
10-26-09, 07:39 AM
if the mechanic fail to apply/spray (not sure what they are called) on top of metal plates that holds the pad, you can get this sound. this stuff stop frictions and sound when you press the break pedal.
if you replaced only the pads without turning the rotars you can get this sound from uneven ware.
hope this help
10-26-09, 06:56 PM
Dont suppose you have salted snowy roads in Dubai over the last few millenia. They probably just have grime that needs to be cleaned off. Seriously doubt that it would be rust?
__________________
2000 Lexus LX 470(Family truckster)
2000 Ford Expedition(Boat puller)
1999 Cadillac Sedan De Ville D'Elegance(p.o.s.)
2001 Ford Ranger (Delivery vehicle)
Tags
2001, 2007, 460, back, brake, brakes, change, clublexus, lexus, lx470, problems, rear, sound, stuck, wheel  |
| Thread Tools |
| Display Modes |
Hybrid Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
