Welcome to Club Lexus, the world's largest and most active online community of Lexus owners and enthusiasts.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Club Lexus community today (click here to register)!
I thought it was 29/32 or something like that. Check the sticker in the driver's side door jamb. The pressure is for OEM-sized P-rated radial tires. Note that LT tires require much higher pressures. Regardless, I inflate my stock tires to 32-33psi front/rear. I find I get good fuel economy and even wear at these pressures. Keep in mind that during the winter, you have to inflate often since a sudden drops in temps can cause your tire pressure to really drop. I find I have to check every month as the weather gets colder, but in the spring, as it warms, the pressure increases with temp, so don't have to inflate as often. Pick a day w/ low humidity to inflate. This will result in less moisture inside the tire, less temp fluctuation, and only helps the rubber life as tires degrade internally due to moisture.
IMO-the numbers on the door give you the 'smoothest' ride, but running 33-36# all around improves mileage and tires last longer...I add 3-4#s...the sticker recs F29 & R32...I run ~F33 & R35 and this seems to give me the best trade-off...(at least that's what I start out with)...probably leaks down a little every week or 2)...34-35#s all around makes it simple...
