LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
Lexus LX570 Mark Levinson Audio, NO VOLUME!!!
Old 11-16-16, 11:34 AM
ShahG
ShahG's Avatar
Default Lexus LX570 Mark Levinson Audio, NO VOLUME!!!
Hey CL.
I got a 2008 Lexus LX570 Australian Spec, Right hand. My problem is that recently there is no sound coming from the ML speakers. Everything else is working, CD DVD radio, just no volume. I checked the fuse, and it was blown, but when I tried to replace it, It blew on me every time as soon as I try to insert it.
I need a solution guys any help will be appreciated. Thank you.
Old 11-16-16, 11:45 AM
ggebhardt
ggebhardt's Avatar
Has anything been installed lately on this vehicle that involved the wiring. This could be a simple short or a blown amp. If the latter is will be expensive to replace unless you can find one used.
Old 11-16-16, 10:29 PM
ShahG
ShahG's Avatar
Nothing has been replaced. I was driving home and all of a sudden the volume cuts out. It's been dead since then.
Old 11-17-16, 04:12 PM
ryanpw3
ryanpw3's Avatar
Recently had similar issue on my 14 with 38k miles. Issue resolved itself when turned off and turned back on, but the dealer said there was a code stored for an issue with the USB port that shut down the speakers that one time. They are ordering / replacing the USB port on the center console just out of precaution.
Old 11-02-18, 04:06 PM
hemicuda13
hemicuda13's Avatar
Hate to dig up an old thread but my 09 LX 570 stopped playing sound today out of the blue. I wanted to see if this was resolved and if so how?
My situation doesn't play music from any source. Navigation voice still plays through the speakers as does the voice control trigger. No volume number displays on the screen when I turn the **** either. It does display a "volume off" message when I press the volume button though. Any one seen this before or have any thoughts?
Old 11-04-18, 07:17 AM
Reggie1
Reggie1's Avatar
Sounds to me like a Mark Levinson amplifier failure. Failure is typically due to heat or to water damage. Signs are as you describe. Lexus has a marketing deal with Levinson that forbids Lexus opening the units to repair them, so the dealer fix has to be a straight replacement with a new amplifier. This is not cheap. My dealer estimate for the one in my LX some years ago was around $1200. However, they can be removed and repaire; it's just that a Lexus dealer will not do it. I found a specialty mail oder repair shop, removed mine myself, sent it off, and had a working unit back for $600 a few days later.
Old 11-04-18, 04:29 PM
hemicuda13
hemicuda13's Avatar
So after not working all day on Friday with multiple restarts, it seems to be working like normal again. Should I assume that it is only a matter of time for a final failure? Or might it have been something else?
Old 11-05-18, 05:12 PM
ShahG
ShahG's Avatar
I got mined repaired and it solved the problem. They will open the amp up and fix it. If your car isnt under warranty, get it fixed or look up used.
Old 06-22-20, 11:09 AM
hb570
hb570's Avatar
I am in the same boat with 2013. Is this just anomaly, or will this only get worse?
checked fuses & all fine.
How can I determine the AMP part number for 2013 570 without removing it from the vehicle, just to get a quote
no audio
I restart the car and the volume works.
Another instance, I tried to turn up the volume and I hear a screeching sound from speakers.
Old 01-26-21, 11:53 AM
Dortega68
Dortega68's Avatar
DO you have the link to this mail in order?
Old 01-26-21, 11:55 AM
Dortega68
Dortega68's Avatar
What did you do to fix the issue?
Old 01-26-21, 02:05 PM
hb570
hb570's Avatar
Default Amplifier PN 86280-0WA40
no audio
Mark Levinson Amp repair -United Radio Amplifier PN 86280-0WA40 quote received. Remove under driver's seat & send for diagnostics/repair $ 675.00
Old 01-28-21, 10:48 AM
nayak1
nayak1's Avatar
United Radio is an authorized third party repair for some of the brand name electronics. I sent my Sony soundbar for warranty repair.
pbxcomm
10-12-16 12:25 PM
hisstojay
03-29-16 11:56 PM
tank5269
07-09-12 09:38 PM
flipflop
01-23-12 10:14 PM
TRedd
ES - 5th Gen (2007-2012)
04-28-09 10:52 AM
Quick Reply: Lexus LX570 Mark Levinson Audio, NO VOLUME!!!
