Really stupid rear entertainment questions
Hi guys/girls, I just found these forums and have 2003 LX and can't seem to get the rear entertainment system (RES) to work. The manual looks like it goes with 2002 models, which might explain my confusion. BTW I do have the remote control and have tried using it as well. Anyway, here are the issues:
1) RES screen had sticker on it from factory that says you need headphones with wires, even though they gave me wireless headphones
2) RES screen says "no DVD" even though there is a DVD in the 6 disc changer. The manual looks like it refers to a separate DVD changer, but damned if I can find one.
3) The "Display" screen on the NAV has a button that says "Rear Off" and if you push it, it says "Rear Off" highlighted. Not sure what that does?? Doesn't ever say "Rear ON"!
4) Not sure what the FM modulation does? or how you put it on FM whilst trying to listen to a CD or DVD
I have gotten the DVD to work on the front NAV screen after finally figuring out you needed the parking brake on........
Much appreciation from a new LX owner.
THANKS
Jim
THANKS
Jim
Open the rear hatch, on the right side there is a plastic piece that you need to open, DVD player is there. You will probably have to drop the third seat flat on the right side to get to it. Use menu buttons to get to FM screen, will allow you to use the system through the speakers.
2004 LX Rear Display Screen
THANKS
Jim
THANKS
Jim
DSW
06-11-11 08:08 PM
