LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
LX470 electrical (wiring) diagram
Old 09-27-10, 07:40 AM
Cibao
Cibao's Avatar
Default LX470 electrical (wiring) diagram
Hello.
I have a 2000 LX470 and really need a electrical (wiring) diagram. I am having some electrical issues like no rpm needle movement and no oil pressure needle movement. Don't know what's going on. They were working fine and suddenly now i have no rpm and no oil pressure readings.
Also, where's the AC Fan's relay?
Thank You all and my congratulations for this super well informed site on Lexus vehicles.
Old 09-28-10, 01:47 PM
Cibao
Cibao's Avatar
Well....I've got it!
So, if anybody needs any electrical diagram......just let me know.
I just signed for a Toyota/Lexus TIS and there's everything.
Old 09-29-10, 08:37 AM
Cibao
Cibao's Avatar
Originally Posted by Cibao
Hello.
Here's the pic of the condenser fan relay in case anyone needs it.
Old 10-03-10, 03:59 AM
jejohnso23
jejohnso23's Avatar
Do you have a wiring diagram of the tachometer and the obdII port?
Old 10-04-10, 05:56 AM
krye
krye's Avatar
I have a 2000 LX470 and just recently replaced the condenser relay. The plug was corroded. NH winters certainly make the problem worse. You can get at it by removing the left headlight and trim. I replaced the relay with a 30A headlight relay and plug from Radio Shack for about $10.
there is a 15A fuse for the gauges inside the vehicle on the left kick panel I do not believe its located in the engine compartment
Old 10-04-10, 01:13 PM
Cibao
Cibao's Avatar
Yes, I might.
Document is in pdf format, let me see if i can find it.
Old 10-04-10, 01:39 PM
Cibao
Cibao's Avatar
Here you go....maybe this help
File Type: pdf
File Type: pdf
File Type: pdf
Old 10-04-10, 06:16 PM
krye
krye's Avatar
Do you have dissasembly info to remove the combination meter? I need to replace the Drive indicator light
Old 10-05-10, 07:28 AM
Cibao
Cibao's Avatar
Hi Krye: Let me tell you that the combination meter is easy to disassemble. The only trouble you'll get is to reach for the drive indicator lights. They are LEDs so it might be difficult to replace. You can not use any common bulb. Also, in order to reach for these lights (PRND2) you have to remove carefully all gauge's needles (RPM, Speed, Oil, Gas, Temp...etc). Use a fork to do that.
Anyway, here's what you asked for....
File Type: pdf
File Type: pdf
Old 10-08-10, 05:09 PM
krye
krye's Avatar
thanks for the info. Looks like I will wait until I have an afternoon to explore
Old 08-22-11, 01:31 PM
presas4846
presas4846's Avatar
hi friends. i try to find the wiring diagram of this zone. because a broked tire damage all that cables. and i cant put together because the colors changes thanks..[IMG]C:\Users\Gerencia.ODALYN\Pictures\cable.jpg[/IMG]
Old 08-22-11, 01:32 PM
presas4846
presas4846's Avatar
sorry is this [IMG][/IMG]
Old 08-11-23, 05:16 PM
mokey96732
1st Gear
mokey96732's Avatar
Default Lexus 470 ECU wiring help
Hello sorry to revive a old thread i was wondering if anyone has the ECU wiring diagram
Old 08-11-23, 05:21 PM
hankinid
hankinid's Avatar
Default Check the 100 series forum...
...on ih8mud.com
Old 10-03-23, 10:40 PM
Saady424
3rd Gear
Saady424's Avatar
could you possibly help me with wiring diagram for the AHC? My right passenger side front and back lines are burnt near the exhaust area and so my codes are C1721 and C1723. Will have mechanics cut and splice and fix but wiring diagrams for the AHC and that area would help. Thank you!
mikeivan
LX - 3rd Gen (2008-2021)
15
05-09-23 01:49 PM
grsams
09-08-15 11:36 AM
RXGS
Maintenance
07-02-09 08:58 PM
mr_z06
07-26-07 08:30 PM
Quick Reply: LX470 electrical (wiring) diagram
