Will 2015 LS stock rims fit my 07 LS460L?
This black set is up for sale and I have first refusal. They are an inch bigger at 19inch. What would be a good price for a set of 4 with approx 75% tread? Is it an upgrade? Do people like the look of it if it works? I'm not going to get warning signals or anything like that on the dashboard am I? Will the pressure reading still work etc. Thanks in advance.
The only thing to might want to check is the size of the tire on the 19" rims. Depending it could throw off your speedometer. Here is a link to a site where you can enter the specs of your existing wheel and tire and then the new one. The diameter should be close, otherwise your speedometer won't read correctly.
For example if you go from 235/55/18 to 225/50/19 you will go from 28.2" to 27.9", which will be close enough.
http://www.onlineconversion.com/tire...conversion.htm
One last question (I've agreed to buy them and got him down to a grand for all 4 wheels and tires)
Will I have to take the air pressure sensors out of my wheels/ tires and put them in the new ones or is it a simple case of take my 4 wheels/tires off and put the new 4 on? Are their sensors in the new 2015 LS wheels/tires that my car will start monitoring or is it not that simple? (Like it never is)
Thanks!
Thanks!
i passed on them in the end, didn't look right on the vehicle, made it look too dark and moody, ha. And my wife thinks would attract negative attention.
I was going to buy them and have them dipped a lighter color but too much messing about mounting etc
marcoes300
05-23-11 02:51 PM
Skitso-3
Wheels, Tires & Brakes Forum
03-15-10 10:26 PM
