Bluetooth Music
Old 04-02-14, 10:07 AM
dapimpee
dapimpee's Avatar
YOu can read all info about BT compares to other types here.
http://www.crutchfield.com/S-kG26TmC...d_quality.html
Old 04-02-14, 10:21 AM
tyrenfroe
tyrenfroe's Avatar
Originally Posted by sktn77a
The newer AptX capable bluetooth systems are designed to improve this but apaprently even those sound inferior to a direct wired aux coonnection
You are entirely correct and I was mistaken.
The bandwidth limitations inherent in the BT transport specification require compression of music data at rates that necessitate some degree, often substantial, of data loss. While the aptX codec directly targets this issue, I can find NO documentation or clear claim that bit-perfect CD sources are (or can be) reconstructed by aptX-enabled receivers. Therefore, I conclude that current implementations of BT-transported and codec'd music is of lower fidelity than that achievable using digital transmission by direct wire or other wireless transport mechanisms (i.e. Apple Airplay). Whether these differences are readily detectable by real-world listeners in typical automotive environments is a subject for empirical testing not speculation. Thanks again for the correction.
Old 04-02-14, 11:19 AM
sktn77a
sktn77a's Avatar
Originally Posted by tyrenfroe
(BTW, your last comment privileges subjective bias over objective, scientific analysis. Not a good thing in cancer research, not a good thing in audio.)
Absolutely agree - randomised, double-blinded testing, though scorned upon by the "golden-eared" audio community, is the only way to eliminate subjective bias from the equation.
sideswipe
06-28-17 07:49 AM
l33ks
07-25-16 10:26 AM
Chilo
01-05-16 11:13 AM
gipsonke
RC F (2015-present)
12-26-15 04:27 PM
Rexus300
05-07-14 10:20 AM
Quick Reply: Bluetooth Music
