Kumho tires cracking on the inner sidewall
Old 01-28-14, 10:14 AM
I8ABMR
I8ABMR's Avatar
Kumhos are cheap *** tires plus you are using the wrong size in the front. I would also avoid the ****ty Falkens also. The tread will separate really easily . You can get Pirellis cheap and they will hold up better
Old 01-28-14, 11:26 AM
1Putt
1Putt's Avatar
Originally Posted by f0unta1n
I ordered the same tires in a 255. I didn't want mismatching tires because the rear tires are fine. maybe it was the load index issue and I was only running 38psi. I got 2 new tires off eBay 206.00 shipped for both so it was hard to pass up for now. Hopefully nothing is wrong with them but they have a 14 day return policy. Will have them inspected before install. Off subject but what do you guys recommend for keeping my cv3's clean is there like a wax or sealant I can use? Thanks for the feedback guys
I'm trying Rejex sealant right now on my VIP mods... so far OK. There's many wheel waxes or sealants. If you're still running the oem brake pads, you may want to try Akebono ceramics or Hawk (forget which model) to cut down on the brake dust.
Old 01-28-14, 11:58 AM
whitetooth
whitetooth's Avatar
Right, I was not happy with the Falkens, too noisy. Pirelli is 74dB, not a silent tire. I'm using Dunlop SP Sport Maxx GT. With 70dB this version seems to be quiet. I like to test Michelin as next step. All around 265/30 ZR22, 9x22,offset 27, perfect match.
http://www.carid.com/lexani-wheels/c...ed-423175.html
2011gs350
12-13-17 09:15 AM
njatl
RX - 1st Gen (1999-2003)
07-08-15 01:28 PM
hades281
02-09-10 10:20 AM
Damage
IS F (2008-2014)
23
01-14-10 01:26 PM
autodriver
Maintenance
05-22-04 01:19 PM
Quick Reply: Kumho tires cracking on the inner sidewall
