Brake Actuator Help
Old 01-20-14, 05:32 PM
onepointon
onepointon's Avatar
Just to confirm, its not a safety issue. Its just a noise that comes from it. And yes, the updated part number is for a 600h.
Old 01-20-14, 06:34 PM
Devh
Devh's Avatar
Is the 600h part plug and play. Also do you need to activate the brake actuator when bleeding the brakes.
Thanks
Old 01-22-14, 05:27 AM
onepointon
onepointon's Avatar
Thanks
When looking at the part, the only difference you will see is the part number, so yes, it just bolts up. The TSIB for the noise lists a separate number for the 460 and 600h, but when the parts guy puts the 460 number in, it supersedes to the 600h number.
As far as bleeding the system, we use a utility through the Techstream. The system is electronic and not like your conventional vacuum brake booster style setup. I am not aware of a procedure that would be ok without using some type of scan tool. You'll likely end up with air still trapped in the system and hear a squawking noise from it. Bleeding the brakes on the 460 is a time consuming process to do it properly.
Old 01-22-14, 06:24 AM
Devh
Devh's Avatar
Thanks, great to know information. The more complex these cars get the more I have to rely on the dealer for simple service. At least I don't have to get a new battery registered like I did in my old BMW.
Old 01-22-14, 11:02 AM
LSin75033
LSin75033's Avatar
Since there is a known issue and there IS a TSB on it, I dont understand why Lexus won't just replace it free of charge. I just bought an 09 recently an occasionally hear the noise. I have 59,000 miles and a 3rd party warranty (which I'm assuming wont replace the part). But what's the point of the TSB if they won't fix it?
Old 01-22-14, 11:07 AM
Devh
Devh's Avatar
A TSB is just a way to inform Toyota service centers of known defects so they know how to diagnose problems a little better and also have a Toyota recommended fix.. This does not mean that every part is defective and needs to be replaced.
Old 01-22-14, 11:30 AM
LSin75033
LSin75033's Avatar
Even when the known bad part is making popping noises and thuds?
Old 01-22-14, 12:38 PM
onepointon
onepointon's Avatar
Your car IS also out of warranty. Its not a safety issue, so they aren't required to replace it. Theres an expiration date on a warranty for a reason. If they were required to cover every TSIB part for the life of every vehicle out there, they would likely never make money.
You didn't buy a new car from them, you bought a used car with a third party warranty. Did you even buy it from a dealer?
Old 01-22-14, 01:16 PM
Devh
Devh's Avatar
I'm sure there are many actuators that are working just fine without issue. Even if the part is known for certain eventual failure it's just the luck of the draw and you will have to suffer with it but next time when you purchase a car you can vote with your dollars. Even though this might be a costly problem to fix outside of the warranty period consider the alternative of buying a German brand with a lot more known issues then this car.
If they had to repair every known issue after the factory warranty I doubt there would be TSBs.
It's not a perfect world and there are always acceptable risks.
Old 01-25-14, 06:55 AM
Chaos236
Chaos236's Avatar
Word: Commission
Old 05-09-14, 11:46 AM
Sticka
Sticka's Avatar
This is insane.
Lexus knows this is a problem. They need to step up to the plate.
I called the NHTSA today and they do not have one single complaint for this issue (they do now ).
If we want to make Lexus cover it we ALL need to file a complaint with the NHTSA.
If you have/had a problem with the brake actuator go to http://www.nhtsa.gov/Vehicle+Safety/Recalls+&+Defects
and file a complaint (click at the top right of the screen "file a complaint")
Your information will not be given to Lexus.
Old 05-11-14, 07:51 PM
sktn77a
sktn77a's Avatar
Well, if its not a safety issue, contacting the NHTSA is a waste of everybody's time. It is a customer satisfaction issue for Lexus and, therefore, very bad corporate PR to ignore customer complaints
Old 05-11-14, 09:27 PM
CJITTY
CJITTY's Avatar
Yes..annoyance issue but not a functional or safety issue. Two dealers told me this and NHTSA probably will not do anything
Old 05-12-14, 12:11 AM
LXurious
LXurious's Avatar
Moms 07 camry hybrid had the same issue. The noise was pretty bad for 2 days then on day 3 she got the immediately pull over, bunch of dash error lights. Took it to the dealer it stopped and has not came back a few months and nearly 5k miles later.
Old 05-12-14, 08:54 AM
Sticka
Sticka's Avatar
How is it NOT a safety issue?
My dash says "brake malfunction" and "check brake system" (and others) and says " do not drive the vehicle, pull over immediately and contact dealer"
And the dealer said " do not drive the vehicle, it is not safe to drive with that warning on the dash".
So, again.....how is this not a safety issue?
Quick Reply: Brake Actuator Help
