Has anyone tried these vleds v3 triton DRL lights?
Old 03-20-13, 03:54 PM
2gs300
2gs300's Avatar
Default Has anyone tried these vleds v3 triton DRL lights?
http://www.vleds.com/v3-w-6k-2817.html
I emailed them and they said you don't need any resistor or anything to make them work as DRL and high beam. Still not sure if they will fit inside the housing with the cover
Old 03-20-13, 06:01 PM
305Busa
305Busa's Avatar
According to the vid on the site, they're universal. Looks promising though. Might have to get a set. I'll do some research first and see what I can find as far as reviews
Old 03-20-13, 06:42 PM
adamls2
adamls2's Avatar
I'm not too knowledgeable about our DRL's, but I believe they are the same bulb as the high beam, so wouldn't that get rid of them?
Old 03-20-13, 08:35 PM
Lextrician
Lextrician's Avatar
the problem is that led operate at a lower voltage and the use of decoders are needed as well as loss of the high beams. but if these do what they say then I need a set.
Old 03-21-13, 08:42 AM
2gs300
2gs300's Avatar
According to what they say it should function normal without any kind of decoder and still have high beam
Old 03-21-13, 01:10 PM
Lextrician
Lextrician's Avatar
I was looking at that on there site but I also didn't see anything for our application. (9005, 9006) and it is weird that they have load resistors for them as well for 20 bucks, but I am guessing it is for if you want to use them for turn signals... I want a set but......
Old 03-21-13, 01:26 PM
OSU
OSU's Avatar
Someone actually makes a kit for our DRLs that doesn't cause the car to throw a code. I have it on my LS, I just can't remember who made it. It comes with a decoder box.
Old 03-21-13, 01:30 PM
OSU
OSU's Avatar
Something like these;
http://www.ebay.com/itm/2x-9005-White-LED-bulbs-w-Decoder-for-High-Beam-Daytime-Running-Light-for-Lexus-/121072707418?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ALS460&hash=item1c307ee75a&vxp=mtr
Old 03-21-13, 03:19 PM
2gs300
2gs300's Avatar
well that's the thing, I don't want o drill holes in the bulb cover. that's why I was looking at the v3's. and yes they said the resistors are if you use them as turn signals
Old 03-21-13, 03:30 PM
Lextrician
Lextrician's Avatar
yeah the ones posted above does require modifications because it is hard to get all that in the limited space in the housing, that is why these will be heaven sent if these work the way they are advertised I want a set but I need some clarification.
Old 03-21-13, 04:58 PM
OSU
OSU's Avatar
Doesn't require any modification. The entire assembly fit inside my headlight housing assembly without drilling anything.
Old 03-21-13, 08:32 PM
SBlexus
SBlexus's Avatar
I have the same kit and you don't have to modify as OSU said. It's a pain in the butt to do the driver side but the decoder will go inside the light housing.
Old 11-07-13, 07:46 AM
CJITTY
CJITTY's Avatar
Hey man, wait a second. You mean to tell me you were able to get all the piece parts to install the V3 Triton inside your headlight assembly for the turn signals or for your high beam? Or are you not talking about the V3 Triton? I want to get two pairs to use for my front and rear turn signals. The rears should be easy, plenty of space I imagine, but that round cover on the headlight housing seems like real estate would of been very tight...post up a video of these in action please
Attached Thumbnails Has anyone tried these vleds  v3 triton DRL lights?-triton.jpg
Old 11-07-13, 11:49 AM
1Putt
1Putt's Avatar
I think they're referring to the Ebay set w/ decoders... OSU, please advise
Old 11-07-13, 02:23 PM
CJITTY
CJITTY's Avatar
I think you are probably right
Quick Reply: Has anyone tried these vleds v3 triton DRL lights?
