Pcs , vsc system check light up!! Help me!!!
Old 09-17-11, 05:13 AM
skyyos
skyyos's Avatar
Default Pcs , vsc system check light up!! Help me!!!
2007 LS460L
Check Engine, PCV, and VSC system light came up all of sudden. Tranction control, cruise control and "Hold" system doesnt not work. Does anyone know why is it happening? I recently replaced Air filter, A/C filter and Oil change.
THank you
Old 09-17-11, 05:56 AM
JFNash
JFNash's Avatar
Battery problem?
Old 07-28-15, 01:09 AM
faizan87
faizan87's Avatar
Default 4 Years and no response to your problem
hey skyyos i noticed its been 4 years and no one has responded to your problem so i am hoping u might have fixed it yourself by now, actually i am having a ls460L and have the 2 signs VSC and PCS and was wondering if you were ablt to find a solution for this as i have already done research on internet but did find any proper post or solution for this problem
Old 07-28-15, 04:55 AM
CRowe14
CRowe14's Avatar
I'm not sure how in depth of a search you've done in this forum, but from what I've read, whenthou get a "Christmas tree" (the collage of lights) on the dash, especially those lights, it tends to be that the battery is going bad.
As others would probably recommend, have you currently battery tested for its ability too hold charge.
If it's faulty, I believe there is a sticky regarding the type of battery that works well for the LS, as not just any battery will do.
Hope that helps and others imnsire will chime in.
Good luck.
Old 07-28-15, 08:57 AM
greg3852
greg3852's Avatar
I recently had this, and I took my battery terminals off and cleaned them, put them back on tight and have not had an issue since. Try that, if not take the car to an autozone type place and have them check the battery. Doesn't mean you have to buy a battery from there, but they will check it for free.
bennecc
Hybrid Technology
24
07-04-24 11:10 PM
gsssss
01-23-23 09:57 AM
HarrierRX300
RX - 1st Gen (1999-2003)
18
04-10-16 04:16 PM
ceeps
04-15-13 09:02 AM
gomboy60
13
09-13-08 08:52 PM
Quick Reply: Pcs , vsc system check light up!! Help me!!!
