Steering Wheel Vibration when in Drive and Stopped?
Old 05-01-15, 09:15 AM
james1245
james1245's Avatar
Question Steering Wheel Vibration when in Drive and Stopped?
What would cause a mild vibration in the steering wheel of a 2002 LS430? It only vibrates when the car is in drive and stopped, such as at a stop light. It stops as soon as you begin driving or put it into park. It's not bad but not normal for this car.
The car has 140k miles and had the variable valve timing solenoids replaced. It's a different kind of vibration though and the car was fine after the repair.
Thanks.
Old 05-01-15, 12:04 PM
KING
KING's Avatar
Hmm, I'm not sure, would like to hear more from our suspension people here.
I know the car has the feature where the steering wheel stiffens up the faster speed you are going. Sounds to me like that system may not be functioning correctly. Just a guess.
Old 05-01-15, 12:35 PM
Slvr surfr
Slvr surfr's Avatar
I would start with motor mounts then move to steering rack bushings.
Old 05-01-15, 01:56 PM
ancdmd
ancdmd's Avatar
I agree, start with the motor mounts
Old 05-02-15, 03:02 AM
adilyaqoob
adilyaqoob's Avatar
I had a similar thing in my 2001 430. I thought it was the motor mounts but it was the coil. I got to know this when last week the coil stopped working all together. I changed the coil, now the slight vibration is gone.
Old 05-02-15, 08:53 PM
kkasaki
kkasaki's Avatar
engine mount?
Old 05-03-15, 05:37 AM
Lavrishevo
Lavrishevo's Avatar
As others mentioned, it's the motor mounts. Replace all 3.
Old 05-04-15, 07:47 AM
wise2k
wise2k's Avatar
Before motor mounts and all I'd start by the most simple of all - check your RPMs on the gauge, if they are lower than spec (I'd say lower than 6) then your shakes might be something engine related and the CEL is about to set, e.g. vacuum leak, clogged ports, etc.
This thread may also be a good read https://www.clublexus.com/forums/ls4...placement.html
Imprezario
10-30-19 09:02 AM
brothabear
07-19-19 11:49 AM
Rowdiggty
06-10-13 11:56 AM
Evaveli
Performance & Maintenance
08-14-12 09:44 AM
OBEY414
01-15-12 09:52 AM
Quick Reply: Steering Wheel Vibration when in Drive and Stopped?
