ls430 oil pan! !!!!!!
Old 03-09-15, 12:56 PM
Robles84
Robles84's Avatar
Default ls430 oil pan! !!!!!!
So I had my oil changed at jeffy lube today. And they told me my oil pan and a pretty bad dent. And should be changed. I've raised my car already since it has coilovers. What my question is were can I get a replacement oil pan. Web or local. I can do the job myself. I live in northern California ...san jose to be exact
Old 03-09-15, 02:05 PM
JffGRY706
JffGRY706's Avatar
M&M Imports Fontana CA. no price but in Houston is $100 for lower.oil pan and $75 in S. Carolina
Old 03-10-15, 07:26 PM
sakoa
sakoa's Avatar
Or, you can always take the pan off and hammer the dent back out. Oil pans aren't very thick to begin with, so it's usually very easy to hammer them back into shape. Just make sure that it didn't take enough damage to crack.
Old 03-10-15, 07:39 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
http://www.car-part.com/
Find a used one from a local salvage yard
Old 03-11-15, 08:39 AM
votru
votru's Avatar
Unless super bad dent that may cause problem with the pump inside - I'll leave it alone until need to replace the oil pan gasket due to leakage. Then you can remove the pan: clean/hammer or replace with a new one.....very messy job .
Old 03-11-15, 09:34 AM
R Z
R Z's Avatar
Just curious as to how it got damaged? Did Jiffy lube do it?
Old 03-11-15, 10:46 AM
empringham
empringham's Avatar
OP mentioned he was on coil overs previous to raising the car back up, probably hit some debris on the road thus causing damage to the oil pan.
Old 03-11-15, 01:12 PM
Robles84
Robles84's Avatar
I think it was when I was running late to go to work leaving my house or at work. We have really high speed bumps. I had to raise to get it in my driveway. Then I went to jeffy lube where they told me about the dent. But thanks guys for the help
Old 03-11-15, 01:19 PM
Robles84
Robles84's Avatar
Hey how do you get the pictures on your post like a signature
gemineye
04-01-22 06:21 AM
joaqin
GX - 1st Gen (2004-2009)
01-30-16 07:21 PM
Lyrical
CL of Southern California
04-09-08 08:14 AM
hakes
Maintenance
04-25-07 04:07 PM
GOLDSc300
Maintenance
01-10-04 01:43 PM
Quick Reply: ls430 oil pan! !!!!!!
