Roof trim strip came off in carwash......
Old 02-06-15, 11:35 AM
MX5
MX5's Avatar
Default Roof trim strip came off in carwash......
The strip that runs the length of the roof on the driver's side came off my LS in my favorite carwash. I didn't notice it til I got back to work, but luckily the place is nearby and they were able to find it inside. No damage, and I see how it goes back on, but are there any tips to keep it from happening again? I can't stop using this particular carwash because it is totally touchless, uses hot water, and I need the Bottom Blaster in winter
Old 02-06-15, 11:47 AM
HiloDB1
HiloDB1's Avatar
Check the clips to see if any are damaged or worn. Thats the only thing holding them in. If any are damaged or worn they wont hold securely and they will come out again.
Old 02-06-15, 12:58 PM
Slvr surfr
Slvr surfr's Avatar
Thought about getting these at some point as mine are starting to peel just a bit
http://www.ebay.com/itm/170647205905?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old 02-06-15, 01:23 PM
MX5
MX5's Avatar
Lexus Chrome Roof Top Trim Molding D I Y Kit | eBay
"This product is also not designed to replace your OEM roof molding, this trim is designed to sit right on top of your existing factory molding and enhance the current look." ------- so as nice as that would look on my black LS, it would fly off too unless I make sure the OE molding is secure beneath it.
My clips look fine but clearly something is worn or it would've stayed on in the first place LOL
Old 02-06-15, 04:27 PM
BCrews
BCrews's Avatar
I want less chrome not more- but mine are beginning to peel too...what's the point of the OEM trim pieces anyway- I always get little leaves stuck there in the seam...
Old 02-06-15, 05:06 PM
LS430Lexus
LS430Lexus's Avatar
Mine started to come off. My mom and pop collision shop used some adhesive in the channels that the clips fit into. That was a few years ago and it has held wonderfully.
Old 02-07-15, 06:23 AM
LiCelsior
Retired
LiCelsior's Avatar
yea i was going to suggest some industrial double sided tape to help hold it down.
bam
RX - 3rd Gen (2010-2015)
18
04-22-24 04:10 PM
dapper23
HS 250h Model (2010-2012)
03-13-19 07:19 PM
RA062424
05-19-14 02:49 PM
lexus-is2
12-17-13 11:39 AM
nevernu
ES - 5th Gen (2007-2012)
02-11-11 12:20 PM
Quick Reply: Roof trim strip came off in carwash......
