Are You Using Mobil1 0W-40 Oil in Your LS430?
Old 01-25-15, 10:17 AM
ceedub53
ceedub53's Avatar
Default Are You Using Mobil1 0W-40 Oil in Your LS430?
If so, I'd like to hear your experience using the M1 0W-40 motor oil. Any change in MPG? What is your oil change interval? Any other experience you can contribute? I'm currently using M1 5W-30 and a Fram Ultra XG3600 over size filter. My OCI is 7500-8000 mi. I live in the central valley of California where day time temps easily reach +100 degrees for months during the summer. I've read the M1 0W-40 is a great oil. Thanks
Old 01-25-15, 11:19 AM
XJSFan
XJSFan's Avatar
I use Pennzoil Ultra 5W30 and a Fram Ultra XG3600 and am very happy... Just stay with a 5W30 synthetic oil of your choice. I do use 0W40 in my Jaguar V12 and the engine does seem to love the 0W40 but it usually runs on a 50 weight. Again, stay with the 5W30.
Old 01-25-15, 02:08 PM
Lavrishevo
Lavrishevo's Avatar
Lexus does not recommend 0w-40 for LS models. I also run synthetic 5w-30.
Old 01-25-15, 05:00 PM
Pamperme
Pamperme's Avatar
Stick to what Lexus recommends.
Old 01-25-15, 05:03 PM
Lavrishevo
Lavrishevo's Avatar
Oil weight plays a pivotal role in variable vale timing. This is the main reason why, to my knowledge, 5w-30 is what should be used in our cars.
Old 01-25-15, 05:52 PM
rkw77080
rkw77080's Avatar
Same here - stay with 5W30 as recommended by Lexus. I wouldn't chance it with anything else...
Old 01-27-15, 06:46 PM
campisi
campisi's Avatar
My last oil fill was Mobil 0W-30. Still running it.
0W oil will flow better than 5W oil at cold temps. I'm guessing the reason Lexus didn't recommend it is because it didn't exist or wasn't commonly available when our cars were built. Verify?
Corrected: 10W-30 should be 0W-30.
Old 01-27-15, 07:33 PM
rkw77080
rkw77080's Avatar
Originally Posted by campisi
My last oil fill was Mobil 10W-30. Still running it.
According to the Lexus oil chart on Post #6, 0W20 (shown as green dot) oil was specified for some Lexus models starting as early as 1999.
Old 01-27-15, 08:11 PM
Jabberwock
Jabberwock's Avatar
I've been using full syn 5w-30 (M1, Penzoil, Castrol) like the book recommends in the US. I'd consider running full syn 0w-30 as it is likely a stouter oil with higher quality base formulation than the 5w. Running 0w-40 very likely perfectly OK to run, although probably more expensive but not significantly so....maybe a good oil for Tucson area : )
If I had a newer car that had 0w-20 recommended I'd likely run 0w-30 in it, most likely after warranty period. They are slightly better for mpg but not sure I trust any Xw-20 oils in terms of long term wear on the motor.
Old 01-27-15, 10:09 PM
ceedub53
ceedub53's Avatar
Mobil1 0W-40 uses a class IV base stock (PAO), whereas most of the rest use class III. That's what drew my attention to it, also that it is considered a very light 40. It is considered one of Exxon-Mobil1's best oil. The fact that it is a 40 pulls me away from it even though I live in a hellishly hot place in the summer.
TTBomB
06-24-22 03:08 AM
XJSFan
02-17-14 05:00 PM
zapola6
03-28-13 11:52 AM
biodev
12-23-11 04:45 PM
The G Man
GX - 1st Gen (2003-2009)
51
11-27-07 05:20 PM
Quick Reply: Are You Using Mobil1 0W-40 Oil in Your LS430?
