engine vibration & shaking issue.
Dear Sir.
Model : LS430 2001.
Recently, sometime occured vibration & shaking and rocking on my car.
I'm opened my bonnet and checked ENGINE. I'm see vibration of engine.
This vibration occured low-RPM and low-speed.
Not occured middle or high RPM. not occured ALERM.
Why happend this situation for MY LS430?
Plase advise to me.
Model : LS430 2001.
Plase advise to me.
You may also want to start with the basics... The cause of the vibration may just possibly be rough idling.
Take a look at this DIY https://www.clublexus.com/forums/ls4...-cleaning.html to clean your MAF and throttle body. Please pay special attention to the "Idle Port".
But if you're convinced that you do not have an excessively low idle or rough idle, then I would agree that the 2 engine mounts and the rear transmission mount are likely your prime suspects.
Good luck troubleshooting - please update us with your progress.
Thank's Twix, rkw77080.
This video clip is my LS430's engine.
almost time, My ls430's engine is very nice. But sometime's occured vibration.
Tomorrow I'll go to service center. And i'm wish to repaired my car.
Thank you.
Thank you.
You are right, the shaking seems excessive. What's your idling RPM? How long ago since you replaced your spark plugs? Are you getting any DTC (error codes)? Did this just start happening recently?
Dear Sir.
Model : LS430 2001.
Plase advise to me.
Model : LS430 2001.
Plase advise to me.
To stay on topic, if no codes are being thrown, I'd have motor mounts and transmission mounts checked.
As long as your car is not misfiring then the most logical explanation is the motor mounts are shot. All 3 are wearable items and are usually due between 150 - 200 thousand miles. The rear motor mount (at the transmission) is very easy to do. The front two are a bit more difficult. Do not use aftermarket on these items. They are known to be poor quality.
2 Month ago, Batteries come discharged. So I'm change the battrry do myself.
1. Idel RPM.
Sorry. i'm not checked IDLE RPM. and my LS430 was dressed in a garage.
The Mechanic said to me "IDLE RPM is very low. but need more time to me"
2. spark plug
The spark plug and IGNO coil will be replace this time.
spark plug were 100,000 km used.
3. DTC code
No DTC code
I seems to be misfiring. So i'll change spark plug & IGN coil.
Just so you know, a visual inspection of the mounts does not help. Mine look new from the outside but they are getting close. The rear mount did not look bad but replacing it helped with less movement during shifts. You would never know by visually inspecting it. The rubber becomes soft and flexible and does not isolate vibrations. This is also true of the sway bar bushings.
There could be a few issues occurring simultaneously.
1) Motor mounts
2) Engine coolant temperature sensor
An engine coolant temp sensor would be the most likely cause of a low idle, which would make a motor mount issue even worse. If the motor doesn't vibrate when you drive ~100 km/h, then it's very likely at least one of those issues.
1) Motor mounts
Hello. everybody.
Mechanic are show up check report to me.
1. motor mount
=> is ok.
2. coolant temperature sensor
=> is ok.
3. spark plug and IGN coil
=> is ok.(replace all spark plug and IGN coil)
After use a car scanner, found "VTEC system fail" code.
My Mechanic said to me. will replace "OCV valve".
Almost "VTEC system fail" code is can repaire that replace "OCV valve"
I'm just waiting the this work.
1. motor mount
=> is ok.
=> is ok.
