non navigation ls430 2002 help please
hi there
i have ls430 2002 and it is without navigation system and i wanna add an oem navigation system ,, because i found a cheapest used spare parts ,, and all what i wanna know its what i need to buy to get the full navigation system and did i need to change the old wiring or add some.
and sorry if there is any mistake in the typing because im from saudi arabia
I suggest you do not spend time and money retrofitting the obsolete screen and out of date hardware dvd based application and laughably grainy graphics OEM factory nav into a 2001 LS430.
That's a bargain, if you got the whole instrument screen and trim.
If so, I think you should be able to just fit it in, in place of the ac/ control unit.
But again, you need harnesses that fit into it correctly, now I'm not sure if the 1st gen without nav, is nav ready, meaning you can gain control of your media, like the radio, cd changer and what not.
As for the GPS goes, you need lots of stuff, and placing the screen there wouldn't do you any good. As you will need the antenna and all it's wires. + you will need the GPS control unit in the trunk too.
Complementing what Jabberwock suggested, DON'T BOTHER! The OEM nav suck and is so outdated right now.
You're far off better getting an aftermarket nav system, like a Garmin that would hook up to your windshield. That is if you were after the screen in order to get GPS advantages.
If you just want the looking good factor. Try this aftermarket screen, looks good, and I have seen it many times on lots of LS's.
Check these kits out,
http://www.beatsonicusa.com/stereo/s...us/ls-430.html
And the Nav costs $475.
http://www.ebay.com/itm/like/330275322394?lpid=82&chn=ps
Here's a fellow member explaining his experience:
https://www.clublexus.com/forums/ls4...-in-ls430.html
Luck to you my brother.
Gitbox
06-07-18 10:17 AM
sunsolaris
10-05-08 09:02 AM
akleg4life
03-14-06 09:19 AM
