Questions about '04 stereo and speakers.
I'm looking at getting an '04 LS430 with Navigation. Can anyone give me any information about the stereo system like if it will have an MP3 player or if it is a single/multiple CD player?
What about the number of speakers and/or their sizes?
I read where the sub woofer can have the foam deteriorate over time and sound bad. I'm assuming that can be replaced with aftermarket stuff? If so, what should I go look for?
The stereo does not support MP3, either on a disc or any other input. The only way you'll be able to play your own music without CDs is a cassette adapter, unless you decide to go with a VAIS unit to allow Bluetooth streaming audio or auxiliary input.
There are two tweeters in front, two door speakers in front, two door speakers in the rear, and a sub. Door speakers are 6.5" and the sub is 8".
The car uses some odd impedances, so getting aftermarket speakers may be difficult. I replaced my deteriorating sub with a Polk db840dvc with pretty good results.
Getting big boom out of this system will probably require substantial modification. It's a clarity-focused setup, with clean but muted bass response.
This thread may be able to shed some light: https://www.clublexus.com/forums/ls4...nd-part-s.html
Good luck!
Thanks Amruss...
That's the kind of stuff I was looking for. I don't know that I will need speakers right away but I already had to replace some in my 2010 Camaro so I figured I would get prepared for the Lexus (I'm still a couple months away from getting my buddy's). I think the woofer is my biggest concern.
I don't need any major thump at all. I just don't want it to sound terrible from a busted woofer. I'm sure the OEM setup will be fine for me.
Is your CD setup a single CD or does it come with a multi-CD?
I just replaced my front door drivers and removed the stock sub. Added a DQ-61, 4ch, and mono amp to power it all. I am utilizing the stock rear door speakers (rear fill) and stock front tweeters (as they kick butt). With the sub removed it acts as a 8inch port into the cabin, which is perfect.
It was a super easy install, and don't get why there is no real talk about this as an option. I am putting a post together later this week on the topic.
I thought Marl Levinson had 11 speakers and more powerful amp. base stereo has 7 speakers, pioneer cassette and cd changer on both
I've see material stating 11 speakers for US cars w/ML. This Canadian brochure says 9 speakers. Both are 240W.
https://www.clublexus.com/forums/att...0-brochure.pdf
I see 9 speaker grills on ML cars from both sides of the border. Is there two speakers up front behind one grill ?? Can anyone clarify this?
I also have a non-Nav ML stereo.
I've delayed posting my install up as I need to mount my tweeters in the A-pillars and won't have time for another week or so. This also includes pulling wire from the cross over in the door up to the a-pillar. My stock tweeter/mid driver that are in dash are going out after two weeks of use hah.
I also put the trunk back together in the meantime.
