Does anyone have clear pictures of cam and crank timing marks.
Old 11-16-14, 12:30 PM
zapola6
zapola6's Avatar
Default Does anyone have clear pictures of cam and crank timing marks.
I'm doing the timing belt, when I removed the belt the cams rotated from the 50 degree mark when the timing belt was removed....
I got it back together, but I don't know if the cams line up with the STRIGHT line on the housing or the T.
Help would be appreciated.
Old 11-16-14, 12:36 PM
Lavrishevo
Lavrishevo's Avatar
This may help
https://www.clublexus.com/forums/ls4...tml?styleid=14
Old 11-16-14, 12:42 PM
zapola6
zapola6's Avatar
So in these pictures, would you say he has the crank rotated the 50degrees to unload the valves?
Old 11-16-14, 01:04 PM
rkw77080
rkw77080's Avatar
Here's another way to look at it... Your new TB should have 3 markings: "R-CAM", "L-CAM", and "CR". They should line up as instructed below.
Old 11-16-14, 01:19 PM
zapola6
zapola6's Avatar
Perfect, I needed the TDC pictures....
I like pictures .... Going to re-time a timing belt.... Back with you in a few hours to let you know how it goes.....
Right now I have the cams at the 50 degree setting and the crank at TDC.... I was going off of another thread for cam timing, Did not realize / understand that pictures showed the cams a the 50 degree setting using the T for timing marks.....
Old 11-16-14, 03:49 PM
zapola6
zapola6's Avatar
Pictures are worth a million words....
Thanks You for your help! I was 1 tooth off on both cams....
I just needed adult supervision!
Old 11-16-14, 04:00 PM
rkw77080
rkw77080's Avatar
You're very welcome! Another success story on the forum...
NathanDorn
06-23-14 12:01 PM
Sololock
26
05-30-12 08:56 AM
Vadim540i
SC- 1st Gen (1992-2000)
11-28-10 11:42 AM
sillyboi12
01-11-10 06:57 PM
CBU
Maintenance
08-11-04 09:06 AM
Quick Reply: Does anyone have clear pictures of cam and crank timing marks.
