LS430 Rear sport sway bar on GS?
Old 06-30-14, 08:14 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Default LS430 Rear sport sway bar on GS?
I posted this in the GS section as well hoping to get info from both models...
Does anyone know or might have some knowledge if this rear sway bar would fit the GS... Its certainly a cheaper alternative to the TRD sway and i also heard its 19mm same as TRD for half the price. it looks to me it may fit... Can't beat the price for 19mm rear sway
http://lexus.sewellparts.com/accesso...2004/4639.html
Old 06-30-14, 11:10 PM
RA40
Super Moderator
RA40's Avatar
One of those try it scenarios, remove the bar from the GS and try it on the LS. I wouldn't expect it to fit. Are the bars the same diameter across the other LS option packages? If there is a thicker bar used on the UL, ML, sport then that may be a better option for the LS that will bolt up with minimal necessary changes. Wont be like the stiffer aftermarket ones though.
For example the 2-LS owners with 95-97's can use the rear sway bar from the '98+, that one was thicker.
Old 07-01-14, 12:05 AM
tmf2004
tmf2004's Avatar
the mounting points look identical to the GS rear sway.. if the 2004 GS and 2004 LS share the same rear configuration of attachments points to the end links then it should fit...
19mm thickness should make a difference over stock..
Old 07-07-14, 03:27 PM
tmf2004
tmf2004's Avatar
bump................
Kaspars
15
02-19-18 12:13 PM
bearcav
11-05-17 08:53 PM
SlvBullet
10-09-14 04:49 PM
forthewin
07-18-14 09:33 AM
tmf2004
Suspension and Brakes
06-30-14 09:28 PM
Quick Reply: LS430 Rear sport sway bar on GS?
