2003 LS430 - Headlight Levelling Alarm
Old 01-16-14, 09:45 PM
Arcturus
Arcturus's Avatar
Originally Posted by Tom57
I think those are two completely independent systems. However, they both are likely affected by your climate conditions. I seem to recall that the wheel speed sensor alone can be replaced, or the whole bearing assembly with integrated speed sensor. I've only replaced the entire bearing assembly.
That's what I thought. Just checking as the two seemed to start up close together. For the wheel sensor, it seems to consistently be signalling that the left front wheel sensor has a problem. It starts the alarm when I accelerate up to highway speeds. Then after some driving it turns off. There is also a faint droning noise which I'm thinking maybe a bad wheel bearing. The part is on order. I'll replace it myself when it comes in.
For the headlight levelling I guess I'll have a look when I do the wheel hub. I know we get harsh winters - this one has been particularly bad - with lots of salt so the climate it probably the source. It sucks because these sensors seem to be fairly expensive and I would just assume do without them. I heard you can pull the fuse to disable it.
I'll update you with how I resolve these problems. Hopefully it can be a cheap solution.
Old 01-17-14, 06:35 AM
Tom57
Tom57's Avatar
There is a FAQ on CL here if you've never done the wheel bearing. Here it is:
https://www.clublexus.com/forums/ls4...-06-ls430.html
A bad speed sensor will throw ABS and/or VSC codes. A bad wheel bearing you'll only hear it. Good luck with your repairs.
Old 01-18-14, 05:20 PM
Arcturus
Arcturus's Avatar
Hi Tom,
For the headlight levelling sensor, I came across this in a Toyota Prius chatroom:
http://www.sector13.org/jason/prius/...ghtsensor.html
The sensor assembly looks similar to that of the LS. I haven't seen the sensor yet, but I'm wondering if it's the same - or at least similar.
Think the Prius guys of 2004-2005 have a lot of trouble with these sensors as they aren't sealed well. Water leaks in and corrodes the springs.
When my parts come in, I'll check the linkage first and then if that's okay I'll open it up and see if I can see the same thing. I can do a walkthru for other interested people. Fun!
Old 01-20-14, 09:46 AM
Tom57
Tom57's Avatar
The sensor looks similar to the Prius - same electro-mechanical function. I did not try to take my old one apart. As mentioned above, like the Prius thread, I did lube the new one to try and staunch the condition from recurring due to harsh weather conditions. Be sure you note/mark where the linkage arm is bolted since the arm on the sensor has an adjustable location which affects how the sensor aims the headlights.
Old 01-21-14, 11:20 AM
Tom57
Tom57's Avatar
Check out this thread too ...
https://www.clublexus.com/forums/ls4...t-flicker.html
Old 01-23-14, 05:25 PM
Arcturus
Arcturus's Avatar
Nice link. Unfortunately it won't let me go to page 2. Grrrr
Old 01-23-14, 07:41 PM
Tom57
Tom57's Avatar
PM Sojah for specific info ...
4wheel
07-16-19 10:00 AM
4wheel
05-14-19 10:18 AM
arpeyer
Lighting
06-19-11 12:41 AM
infa_red
Lighting
03-19-08 02:23 PM
posdriftin
02-20-08 06:21 PM
Quick Reply: 2003 LS430 - Headlight Levelling Alarm
