changing spark plugs
Battery may be an issue on the rearmost plug on the right.
I had to release the battery clamp and push the battery as far right as possible to be able to get in without actually removing the battery.
Took me 2 hours, i have never done this before.
I had to remove the plastic on the pass side ofbthe engine and lift up the air duct thing
I found nkg plug and replaced with denso
ND is standard. When you remove the spark plugs it's best to do so when the engine is warm, not cold and not too hot. Less chance of any plug to thread failure. Apply some die-electric grease to the shank of the COP before you re-install it. Helps keep moisture at bay.
Might want a look at this, especially the second and third paragraph. I happened to catch Pat doing this bit on his show recently and thought how things have changed. Back in my time you just slapped the dino on the *** and it went where pointed.
http://www.motorweek.org/features/go...k_plug_removal
