Minor Upgrade - HID Fogs w/Pix
Old 04-29-11, 08:41 AM
  #31
airtime
airtime's Avatar
Originally Posted by sojah
i found it easier for me to get to the fog bulbs from just underneath the front bumper danxp ^ ^ ^,, not saying its the best way but for me it was easiest. i tried the wheel well first and now i go through the underneath.
my friend ordered 5k (GS) and i ordered 6k (LS) and when we compared mine were almost more white (like a crystal white) but with a light hint of an icy blue, sorta like a bmw (in my opinion). the factory headlights are closer to 5k and if you get 6k you will notice how non pure white the stock headlights (HID's) truely are. i think the 6k looks cleaner in the fogs than 5k but 5k is closest to stock hid's.
in my opinion the 5k looks like older tech and the 6k looks like newer tech.
+1 on the color temp match. 5k gives off pure white, 6k gives off white with a tinge of blue. I believe the most lumen is at 5k and the level of visible light goes down as the temp goes up.
Old 04-29-11, 08:49 AM
  #32
airtime
airtime's Avatar
i meant 9006 my bad....
so is a 9006 what the drl bulb is stock on our vehicles?? if so than this is a no brainer for me.
I believe 9005 for DRL. Anyone confirm?
Old 04-29-11, 10:01 AM
  #33
danxp
danxp's Avatar
thanks airtime and sojah...
just ordered the 5000k from that ebay seller... wish me luck...
Old 04-30-11, 08:27 PM
  #34
xuserx04
xuserx04's Avatar
Yes High beam/DRL are 9005.
Old 04-30-11, 09:05 PM
  #35
dejavu157
dejavu157's Avatar
4.3k for the win!
Old 04-30-11, 10:39 PM
  #36
2SAVVY
2SAVVY's Avatar
Would running 9005 LED's with a harness give the output that we are looking for? One of CL's vendors has this but i'm a bit confused what I would need.
http://www.v-leds.com/Exterior-LED/D...97704-1-3.html
http://www.v-leds.com/9005-HB3/LED/s...orLanding/true
I don't think these are dual LED's so I would lose my highbeam capabilty. Can someone fill in the blanks for me?
Old 05-01-11, 06:47 AM
  #37
sojah
sojah's Avatar
i have the modules ^ ^ ^ (in the first link) with some 9005 6k (look more like 7k) bulbs from them too. this enables your drl to be on full blast if you will all the time. in our cars stock the drl is only on half power (why it looks so dull in the first place) then when you flick on your brights they go to full power. so the modules make it full power all the time which look bright but don't put out much usable light at all.
so you will loose the light output from the brights/highbeams, but you can still use them and flash them and what not. this will make them look like bad *** drl's but not very functional light output.
Old 05-01-11, 11:47 AM
  #38
2SAVVY
2SAVVY's Avatar
Thanks for the insight sojah. I don't mind losing the high beam ability. So the bulbs you got from this vendor is this below?
http://www.v-leds.com/Exterior-LED/D...52845-1-2.html
BTW airtime great job on the 3000k fogs. I just ordered mine. Looking forward to installing them. I currently have LED 4300k fogs and honestly they look like crap (colour doesn`t match and light ouput is way to dim)
Old 05-01-11, 12:06 PM
  #39
sojah
sojah's Avatar
Yup those r the bulbs I have, just make sure to get a pair of the modules. They look awesome but don't put out any usable light, similar to all the new led lights on new model cars.
Old 05-03-11, 04:54 PM
  #40
imherenow
imherenow's Avatar
Easy. Take unplugged wire from factory bulb, then plug into the ballast. Ballast output wires then connects to the HID bulbs. Its male/female so you cannot make a mistake even if you want to. I think a 5 year old can figure it out.
Test before you put everything back together. Note: you have a 50/50 chance of getting the plug into the ballast the correct way, if it doesn't light up, just turn it around.
Its incredible how a 35w lights up so bright. They also do sell a 55w HID kit which would be insanely bright.
So i m in process of gettin 3000K H3 for my fog lights too and so i have heard that they sell slim and non-slim ballast HIDs. beside the size is there any other differences? i think i will get the non-slim (regular) one for around 65$$$. And where did u put the ballast ..had to drill holes i assume?
Old 05-03-11, 11:57 PM
  #41
tsslaporte
tsslaporte's Avatar
Why does the OP look like glare city? Whats the cutoff, if you have one.
Old 05-04-11, 10:27 AM
  #42
airtime
airtime's Avatar
I had imaging it may glare but not really. In the back of the fog lights, there is a wheel for adjusting the aim if needed.
Old 05-04-11, 10:29 AM
  #43
airtime
airtime's Avatar
Non slim and slim works the same. It seems though the slim has a sealed plastic housing that may prevent rust vs the full size metal. No need to drill hole as you can zip tie it to a number of things behind the bumper area.
Old 05-04-11, 10:30 AM
  #44
airtime
airtime's Avatar
NOTE: I'll be starting a new thread soon on installing the HID DRL
Old 05-04-11, 11:00 AM
  #45
imherenow
imherenow's Avatar
thanks..ya i think i just going to get LED for DRLs. no need to put HID for DRLs..just LED for show. since well they are justy DRL..but lets say if i were to put on my high beam on will the LED become brighter ..(like with halogen) or will be remain same brightness?
Quick Reply: Minor Upgrade - HID Fogs w/Pix
