04 LS folding door mirror going crazy
My driver side door mirror on my 04 LS Ultra is going crazy. When I turn the ignition the mirror unfolds but it will not stop at the normal position it continues until it can't go any further. The part that retracts is slightly lose and I do not see how it can be tighted, if I apply the slightest bit of pressure it will stop in its proper place. I think that it is some type of spring loaded unit. Can the unit be repaired or must it be replaced?
Thanks in advance
Thanks in advance
I had a similar problem a while back but it was cause by a low battery. I was leaving my keys in the car overnight and it was slowly running down my battery. When I wouldn't drive for a few days, the mirrors would go crazy. I don't leave them in the car anymore and it hasn't happened since.
BTW, post some pics of you car with the black chrome wheels.
The battery was changes about 20 months and 35,000 miles ago. Strange, I will charge the battery and see if that helps.
Here is a low resolution pic of my LS.
my 2004 LS430 just started doing that on drivers side. It randomly folds and unfolds 180 degrees towards the front, I have to reach out the window and pull it back into position. wish there was a cheap fix.
SerasLibre
08-02-23 10:47 AM
