My first DIY- HID bulb replacement
Old Sep 14, 2008 | 01:34 PM
So Philly1's Avatar
So Philly1
Default My first DIY- HID bulb replacement
So i guess all DIY's start this way. I went to a speed shop to buy some different color HID bulbs for my lows and a kit for my fogs. The low's were replacement bulbs and they wanted $175 for the bulbs and $75 to install. The fog light kit they said was $120 and install of $80. So $450 bucks to change my lights!!!! I wanted to slap those guys just for GP. Anyway today (sunday) while the giants were playing i got my ebay kit and replacement bulbs for my low's and got to work. All i needed was a screw diver and a metric 10mm socket wrench. BTW which cost a total of $130. And this is how it went....
First I started on the passenger side since was easiest to get to, and i could look how things were so i know how to put them back after i'm done. I took of the covers with the screw driver. There's a round twist off cap you take off to get to the lights.
When you twist it off this is how it looks.
There are two small clips holding the bulb harness in place. There very easy to pull out. They are like tabs and you just pull them down.
Here is the bulb removed.
A small twist and pull and actual bulb comes right off.
Just replace with the new ones, test and put it back just the way you found it!!
And the other side. Pull the covers off and use the socket to move these pieces out of the way. The arrows are pointing to where the screws are.
Once you have enough room its the exact same process!!
The fogs were done by me & one of my boys. We didnt take pics because it was tooo hot under the car. But it was too easy and took less than an hour.
So i saved money and got the satisfaction of DIY. Damn i feel like i can conquer the world now!!!!
And the finished product
I'll take night shots later. But whaddya think??
Old Sep 14, 2008 | 01:40 PM
froboy272's Avatar
froboy272
cant wait to see the night shots philly
Old Sep 14, 2008 | 04:54 PM
GSoup's Avatar
GSoup
CL Folding 10,000
Nice write up. How many K are your bulbs?
You did your mods in a handicap parking space LMAO
Old Sep 14, 2008 | 05:07 PM
mikemareen's Avatar
mikemareen
nice thanks!
any chance u can give a description of the DIY for fogs? would u recommend I get the slim ballasts or go with the normal size ballast for fogs? Is there enough space in there to tuck and tape a normal sized ballast ?
Old Sep 14, 2008 | 06:03 PM
SH212's Avatar
SH212
Dances with goats
LMAO!!.....
Old Sep 15, 2008 | 03:46 AM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
Thanks for the write up... I will be adding this to the FAQ on top of the forum.
The bulbs look like they are 8,000-10,000K.
Old Sep 15, 2008 | 05:12 AM
Shilly's Avatar
Shilly
Can you give us the Model, K rating and possibly the eBay Seller for both sets of lights? What difference do you notice? I am probably most interested in the fog light change right now, but will appreciate your DIY when one of the bulbs burns out of my 2001. Thanks for the pics
Old Sep 15, 2008 | 06:37 AM
bonafyd's Avatar
bonafyd
Looks good
Old Sep 15, 2008 | 07:29 AM
Tee's Avatar
Tee
I really want to see the night shots!
Old Sep 15, 2008 | 08:02 AM
junjdm's Avatar
junjdm
what is the watts on the bulbs? cuz i thinkt he bluer your go.....the less lighting you will get.....but it looks good.....not my choice....but looks good...
Old Sep 15, 2008 | 08:03 AM
junjdm's Avatar
junjdm
oh....and are you selling your OEM bulbs? Let me know if you are...you can PM me.....if that is an option. Thanks
Old Sep 15, 2008 | 08:35 AM
So Philly1's Avatar
So Philly1
Bulbs are 20000k And yea thats my space in my building!! No really it is
Originally Posted by mikemareen
nice thanks!
You dont need the slim ballast just buy the 9006 ebay kit. It was kind of hard for us to mount the ballast so we just tie wrapped it real tight. The regular ballast fits fine.
Both ballast and replacement bulbs are 20000k. I got them off of the ebay seller HIDNY. Hope this helps
I like the look of the 20000k's. And believe it or not it shines brighter than you might think. Everything and i mean everything reflective GLOWS in the night. I have no problems seeing anything. But thats just me.
Old Sep 15, 2008 | 08:56 AM
GSoup's Avatar
GSoup
CL Folding 10,000
You do realize the higher you go in K (ie. 20K) you lose visibility and you get more light dispersion. As the "K" goes up, the lumen/brightness decreases. It will get "bluer" as you go up which your eyes perceive to be brighter.
Old Sep 15, 2008 | 12:48 PM
So Philly1's Avatar
So Philly1
Actually i do. I actually did my research. But like i said i like the look and i can see clearly with them. My goal was to go the highest k without looking like a 9v flashlight. And i think i accomplished that I appreciate the info & concern tho.
Old Sep 15, 2008 | 02:06 PM
airtime's Avatar
airtime
CL Folding 1,000,000
We need some night time shots
I've seen many Honda Civics and the likes with some really blue looking xenon and it pretty annoying to look at. It looks super bright within the first 20 feet or so, then the brightness somehow drops off to the point a regular headlight would brighter. I hope yours is not that blue.
Also, I need to confirm if I'm reading this correct, you have a 20K color temp? It starts to get blue after 10k and at 12k it really shows.
