Timing belt replacement tip
Old 10-15-03, 06:43 PM
bertjnovak
bertjnovak's Avatar
Default Timing belt replacement tip
If you are replaceing the timing belt this would be a good time to service the power steering also.
Since the power steering pump must be loosened any how, remove the reservoir and flush and replace the o ring at the base of the reservoir. This may save you a pump replacement down the line.
This o ring deteriorates and allow air to be sucked in thus causing foaming of the fluid and a noisey pump.
Old 10-15-03, 09:09 PM
bluestar
bluestar's Avatar
Does 2nd gen ('98-'00) LS have timing belts or chains ? Just wondering bcos my '99 is coming up on 80K miles and wondering if I need to prepare for this change.
Old 10-15-03, 09:15 PM
bertjnovak
bertjnovak's Avatar
I understand they all have timing belts that should be replaced around 100K.
While its apart also replace the water pump ,idler pulley and serpintine belt.
Old 10-17-03, 08:12 AM
VQT
VQT's Avatar
Do you have the O-ring part number for the P/S pump? Is it the same for all LS years? mine is a 99 LS400.
Thanks,
Old 10-17-03, 08:37 AM
bertjnovak
bertjnovak's Avatar
I do not have the part number of the O ring but if you take the reservoir to any auto parts store the can match it up or check Lexus parts
Old 10-19-03, 08:31 AM
spxChrome
spxChrome's Avatar
They all have belts as far as I know. But before just replacing it because it is time, I would inspect it first. Sometimes you can get way more than the recommeded 90K replacement.
Jasoneo5
10-31-05 11:26 AM
T0ked
Performance & Maintenance
10-07-04 10:53 AM
tantheman
02-27-04 11:25 AM
FLMNLX
04-18-03 11:11 PM
BriMcc
02-20-02 05:46 AM
Quick Reply: Timing belt replacement tip
