Over Heating Issues 1994 Lexus LS400
Old 05-08-15, 05:23 PM
Tr3y1990
Tr3y1990's Avatar
Default Over Heating Issues 1994 Lexus LS400
Yeah she been acting funny the other day when i was driving i noticed the temperature gauge was Raising up and she only did it while i was at a complete stop but when i drive she cools down but the next morning while i was driving to work and i made it but i noticed steam coming from the radiator on top there was a crack i don't know what cause has any one ever experienced this but she has been trying to over heat for the longest but automatically cools down once moving i tried changing the radiator cap and the thermostat nothing helped maybe it was a clogged that caused the issue
Old 05-08-15, 06:34 PM
sha4000
sha4000's Avatar
Is not overheating while driving because air is being forced onto the engine and is keeping it cool. Once you stop the cooling effect stops. If you have a Crack in the radiator then you need to change the radiator out. Your losing coolant that's why you see steam. Once the coolant hits the hot engine it vaporizes and turns to steam.
Old 05-08-15, 11:03 PM
dicer
dicer's Avatar
If the electric fans aren't working it can have those symptoms and also engine fan clutch. On hot days with AC running it kinda needs them all. When the radiators get old the material they are made of gets a bit crispy, time for a new radiator.
Old 05-09-15, 12:07 AM
RA40
Super Moderator
RA40's Avatar
How many miles on car? That crack will grow from the heat cycling and better to get it replaced ASAP. The possible result for letting it go is that you'll be talking with your mechanic about a blown head gasket situation. As in lots of steam coming out the exhaust along with a chocolate milk color to the coolant or oil. That's to late by then and with warmer weather coming on, this is a definite bad situation.
itzmedeezy
09-12-14 11:55 PM
T900RR
08-15-14 07:19 PM
Avster
RX - 1st Gen (1999-2003)
09-04-13 03:21 PM
ES300Ride
03-28-11 12:18 PM
shaned1320
19
06-15-09 02:33 AM
Quick Reply: Over Heating Issues 1994 Lexus LS400
